Direct Fit Magnaflow CAT
Car: 92 Camaro RS
Engine: 305 TBI
Axle/Gears: 10 Bolt 3.42 Posi
I have a direct fit magnaflow cat and have never installed a cat before and would like to know what I need to do to make this process smooth. Will the cat come out and go on easy without taking off the entire Post Cat?
Car: 92 Camaro RS
Engine: 305 TBI
Re: Direct Fit Magnaflow CAT
Nevermind it just unbolts and the post cat exaust just moves out the way. The hardest part is unbolting them rusted #^% bolts.
Car: 92 Camaro RS
Engine: 305 TBI
Im having a hell of a time taking sliding the old converter off the pre cat part any tips to make this easier?
Car: 92 Camaro RS
Engine: 305 TBI
Yea, I got it soaked in PB blaster, that SOB is TIGHT!, I tried opening it up a bit by jammin a screwdriver in between it seem to help a little. Thanks
Car: 92 Camaro RS
Engine: 305 TBI
This is my suggestion to anyone planning on doing this job.... If you know how to weld and have access to a welder get a weld on Cat, if you dont get one anyway and have someone do it.
Car: 92 Camaro RS
Engine: 305 TBI
After 4 hrs of hard labor in 100*+ weather I managed to get the sucker off. I put the new one on it slid on extreamly nicly, my only concern is that the Air tube on the magnaflow was not as long as the OEM one, so only about 1/2" of the body air tube fit over the cat one.. I clamped it down fairly tightly but I didnt wanna tighten it so much that I cushed them... If I end up having a leak there will I fail smog?
ambainb
Apr 25, 2016 09:21 PM
