Help needed with gasket change
Old Jul 14, 2012 | 12:49 PM
'87IROCZOWNER69's Avatar
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
So on my 87 camaro with the factory 350 I have a pretty large exhaust leak at the manifolds and where it bolts to the engine. The question is, how do I go about changing the gaskets and such. Is there anything I need to remove to access the bolts or to change the gaskets? Everything under the hood is stock so I still have all the smog equipment and A/C and such.
Old Jul 17, 2012 | 12:02 AM
Re: Help needed with gasket change
Done some searching and there has been some back and forth on whether or not these cars actually have the gaskets on the manifolds or not. Can someone clear that up?
Old Jul 17, 2012 | 06:55 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
My stock exhaust manifolds in my 88 had no gaskets.
Old Jul 17, 2012 | 07:55 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
IMO have you checked the tube running up from the Cat. it just seems strange that the manifolds would start leaking unless they where disturbed.
Old Jul 18, 2012 | 12:37 AM
Are you talking about the AIR tube? If so I will check it out in the morning. As far as I am concerned they have not been touched, just sort of started after this last winter.
Old Jul 18, 2012 | 07:20 AM
Edwardgp's Avatar
Engine: 454-350
That's is it, I don't run a cat and forgot the name. IMO I would check the air tube and the joint were your exhaust attaches your manifolds before attempting to remove them.
NinjaNife
Aug 23, 2015 11:49 AM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
kyleb24
Aug 15, 2015 08:24 AM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
