cutout causing issues
Old Sep 13, 2012 | 09:52 PM
Kandied91z's Avatar
this season i installed a cutout on my exhaust setup and it seems to cause some major issues. I'm curious if this is common as i've never ran one on a car before. particularly during idling or low cruising speeds to the point that over the summer the car completely cutout as if it were out of gas after running in a cruise with the cutout open. Has this happened to anyone else?
Old Sep 13, 2012 | 10:17 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
Re: cutout causing issues
where is the cutout placed in relation to the oxygen sensors? are you still running a gm ecu?
Old Sep 13, 2012 | 10:39 PM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Was just about to ask whether your O2 sensor was before or after the cut out. I wonder if you burned a valve? Although I don't really see that being very likely to happen.
Cornholio7979
Sep 20, 2018 02:31 AM
Americanmouse
Sep 7, 2015 12:10 PM
formula_novice
Sep 5, 2015 03:58 AM
greenyone
Sep 2, 2015 03:39 PM
crazynights
Aug 21, 2015 06:53 AM
