PICS OF MY 3"DUALS WITH X-PIPE
Car: 1985 firebird
Engine: 360"sbc NA pump gas
Transmission: Th350 manual valve body
Axle/Gears: Moser 12 bolt 4.11:1
Had this system since 07 so there's a little corrosion on he welds, keep in mind this is a 3" system with a dynomax tandem x-pipe on a lowered car.
clearance under x-pipe
Car: 88 IROC-Z (L98)
Engine: Edel. Lwr, SLP Rnrs, Ported Plenum
Transmission: 700R, 2800 Stall
Axle/Gears: 3:42 Posi.(4th gen.) UMI R/Susp.
Re: PICS OF MY 3"DUALS WITH X-PIPE
what kinda mufflers do you have.. thinking of doin a similar setup but w/ an H pipe.
How loud is she..?
How loud is she..?
Engine: 4++,350 & 305 CIs
If you could put a space between your image tages then we won't have to scroll all across the globe to see the pix.
Car: 1985 firebird
3"dynomax bullets,it's not quiet for sure. But you don't see the exhaust hanging low like most duals on third gens
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Type first than hit "enter" key to jump below and stack photos the same way.Photo ,then hit "enter" key to jump below.Photo,hit "enter" key to jump below.Like that "only" or you will stretch the page like this by putting the photos side by side.
Car: 1985 firebird
Sorry but they are one on top the other on my iPhone. Just trying to be helpful showing some pics
Engine: TBI,5.0
We just want the new guys to understand the "correct" way of posting photos.
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
how far is your car off the ground at the pinch weld at the bottom of the rocker panels?
looks like your car sits kind of high compared to some of them.. i know my car has less clearance than you do at the lowest point under the trans crossmember, and i'm only running 2.5" pipe there and it's almost rubbing on the crossmember.
Car: 1985 firebird
Cut 1 coil off front springs and coil and half off rear. Here's how it sets
Car: 87 iroc-z
Engine: 454
Transmission: th350
man, thats a sharp looking ride! i think your exaust/fab work is just fine. do you have any videos so we can hear it?
Car: 1983 Z28/2000 ZR2
Engine: CFI to carbed 305/ 4.3
Transmission: Built 700r4/4L60e
Axle/Gears: 3:23/3:73
The only reason I've strayed away from the idea of true duals is because there are a lot of speed bumps in my general area. Yours actually look like they might have a shot at clearing them. Have you run into any yet? If so, how was the clearance?
Car: 1985 firebird
No videos yet ,and I'm not sure how to post em anyway... Has a loud rolling raspy sound though if that helps.
Car: 1985 firebird
Haven't dragged on any yet but always take em slow.
Notched my factory crossmember for ground clearance
Car: 1989 Iroc Z L98
Good looking system, you are running 28" tall tires in the back, that is giving you at least an extra inch of ground clearance. I had a system similar to this on 26" tall tires and bottomed out pretty regularly.
@ingram78 sounds like a beast..My set up will be similar, can't wait...
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
