True duals or y-pipe 1in 2 out?
Old Sep 26, 2012 | 09:23 PM
Glenn88Iroc88's Avatar
Car: 1988 iroc-Z 5.7l TPI
Engine: 5.7l TPI
I know theres a issue with installing duals on a third gen due to clearance issues.. but as of right now my car has a perfectly good 3" flowmaster cat-back exhaust (headers, ypipe, 1 in 2 out) but its just to quiet for me... and i cant help but think that its robbing me of a few hp..... other than sound would upgradeing to "true duals" help HP at all?
Old Sep 26, 2012 | 10:24 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: True duals or y-pipe 1in 2 out?
Run a magnaflow. Do you have headers? Flowmasters were plenty loud on my L03 TBI car, but it had a gutted cat so that might have something to do with it.
Just dont do anything silly like straight piping it.
Old Sep 27, 2012 | 07:57 AM
Engine: 5.7l TPI
Thats a good point infernalVortex.. straight pipeing is bad. yes my car has headers (not sure what brand but there shortys). Thanks!
Old Sep 27, 2012 | 08:07 AM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
You always can go with an electric cut out , loud is not always a good thing...
Also true dials adds a lot of extra weight and with a good 3" system will do just as good
Old Sep 28, 2012 | 10:46 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
Are you still running a cat? Do you have an American Thunder exhaust or the delta force?
Old Sep 30, 2012 | 05:37 PM
gmstrong's Avatar
Car: 95 9C1,99 Sierra,90Sierra,00 sierra
Engine: TBI350,LM7,LT1,Vortec 350
Transmission: 700r4,4L60e,4L60e,4L80e
Axle/Gears: 10 bolt,14bolt,3:42,3:73,3:08,3:73.
how do you figure it adds weight?
Old Oct 1, 2012 | 07:14 AM
Engine: 5.7l TPI
Yes, my car has a cat.. but im not sure which series it is... it has a real deep rumble to it...
Old Oct 1, 2012 | 07:16 AM
Engine: 5.7l TPI
Thanks for your input, bud. i was told a few diffrent things... like the y-pipe 3" catback is just as good as true duals performance wise. then i was told the opposite.
Old Oct 3, 2012 | 04:39 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
IIRC, the 3" single piple flows around 5cfm less than a true dual set up with 2.5" pipes. The difference is maybe 1hp.
mattcanty
Oct 12, 2015 11:08 AM
paul_huryk
Oct 1, 2015 04:27 PM
