Finishd installing my Hooker 2055!!!Sucess Finally
Old Oct 20, 2012 | 09:03 PM
calgutie's Avatar
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
So after much research and thread posting I finished up installing my Hooker 2055 headers. After the heads I decided to run 3" striahgt pipes and as a muffler I went with the Flowmaster 40, and I LOVE THE SOUND of this car! its just right......
H
ere are some piks of it, I still need to order the correct wires becuase my stock wires are gettign burned up...but what do you think should be my next upgrade??thanks!
I can finally check off my exhaust of my Long TO DO LIST for this car...
Old Oct 21, 2012 | 08:01 PM
Buggy Disaster's Avatar
Car: 91' Z28. 70' Dune Buggy
Engine: LSX Cam/Full Bolt ons
Axle/Gears: 4.10
Re: Finishd installing my Hooker 2055!!!Sucess Finally
Nice, how long was the install, and hows the power difference?
Old Oct 21, 2012 | 09:40 PM
calgutie's Avatar
Car: 1984 Z28
the install wasnt all that bad except for the passengers side in which the header didnt wanna go in but finally after trial and error it went in...as for power difference its noticeable but nothing too major, and also the sound is also a big difference compared to stock..
Old Oct 21, 2012 | 09:55 PM
PhoenixFirebird's Avatar
Car: 1989 Firebird Formula
Engine: 385
Transmission: Full Manual TH350
Axle/Gears: Moser 9" 3.70
How much of a performance difference with headers? Well, I can't tell you exactly, but I will tell you my headers/tune only 305 TPI has gone 9.30 1/8th mile. That roughly converts to 14.50 1/4 mile. Of course the tune has a lot to do with it, as does the air quality, but headers have a LOT of potential.
Old Oct 22, 2012 | 10:36 AM
calgutie's Avatar
Car: 1984 Z28
yep that true...but my next question is what should my next upgrade be...?
Old Oct 24, 2012 | 07:09 AM
Inspection
Quick, before you get in any deeper
Old Oct 24, 2012 | 10:53 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
If you didn't open up the header at the ball connection, you wasted your time and money.
That hole is the same size as the stock manifold.
Attached Thumbnails Finishd installing my Hooker 2055!!!Sucess Finally-jba3.jpg   Finishd installing my Hooker 2055!!!Sucess Finally-jba-headers.jpg
Old Oct 24, 2012 | 12:02 PM
TheRock86's Avatar
what do you mean don? what would you have to do?
Old Oct 24, 2012 | 05:39 PM
Engine: 385
I would imagine just trimming it down, there's a lot of meat left before the flange.
Old Oct 24, 2012 | 11:51 PM
TheRock86's Avatar
was thinking the same or opening it a bit
Old Oct 25, 2012 | 10:17 AM
Dyno Don's Avatar
Like this....
Attached Thumbnails Finishd installing my Hooker 2055!!!Sucess Finally-dcp_1284.jpg
Old Oct 25, 2012 | 12:23 PM
Guest
Guest
Posts: n/a
Originally Posted by Dyno Don
Like this....
....damn...
Old Oct 25, 2012 | 12:38 PM
TheRock86's Avatar
so let be the same diameter throughout.....not choke it up at end
Old Oct 25, 2012 | 09:08 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Please take into account that Don makes and sells his own headers and the Hookers are his primary competition. Hookers are still some of the best available for our cars, but no header is perfect. Every one has some achilles' heel. Thats still going to be a huge improvement over stock and there are tons of guys with 2055s that go very quickly with them.
Don's headers are better, though, but they're not cheap either. They're priced at about market value for them.
Old Oct 25, 2012 | 11:45 PM
TheRock86's Avatar
yes thank you. I was just curious as to what he meant, i just got 2055 headers from a friend, dont hurt to learn a bit you know?
Also i have a few a friends with Dons headers and have heard nothing but good things as well
Old Oct 26, 2012 | 10:44 AM
Dyno Don's Avatar
Why does he need to take that into account, I was just trying to help.
The Hookers are very nice for some situations but they need help in that area.
Now that he is armed with some good advice, he can go back and make his install better.
Old Oct 26, 2012 | 12:19 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
He can fix it without removing the headers. Put it up on jack stands, remove the Y-Pipe and you can easily get to the flanges to open them up.
A nice bit, and a plug-in power drill or air grinder, and a set of glasses to protect the eyes.
When the Y-pipe is still up I'd use a marker and mark the flanges so you know how much they can be opened up.
I do agree though that why the opening is so small i can't fathom. It boggles my mind on that one.
Old Nov 6, 2012 | 03:31 PM
TheRock86's Avatar
so opening them up a bit i guess is the way to go
Old Nov 6, 2012 | 08:46 PM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
Transmission: 700-R4
Axle/Gears: 3.27 9-Bolt
How far do these headers need to be opened up to really make a difference??
I am about to install my own set of 2055's and I really need to know
Old Nov 7, 2012 | 07:47 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
As they are factory, they are only 2 1/4 inches, see dyno-don's picture above. Opening them up lets them flow 2.5' each or more, depending on how far you want to go with it.
Old Nov 11, 2012 | 04:08 AM
oamhmad's Avatar
Car: 84 Trans AM
Engine: Goodwrench 350 Crate motor
Get rid of the AC dryer canister, you're only one bolt away.
Old Nov 11, 2012 | 09:42 AM
WyoJames's Avatar
Car: 1987 IROC
Engine: 305 TPI swapped to Holly 4bbl
Transmission: WC T5
Unrelated to topic...just thought I would quote this good advice that a lot of people over look.
Old Nov 19, 2012 | 05:06 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
That's surprising that hooker would make a piece that's that restrictive. I've always ran hooker super comp long tubes and they're always awesome looking and performing.
I'm thinking it has something to do with the fact that the 2055s aren't really made for max performance.
Old Nov 20, 2012 | 04:49 AM
Ozz1967's Avatar
Car: 1984 Trans Am
The 2055's are a huge upgrade over the factory manifolds, so they really don't need to make them larger. Besides, it's a small thing to enlarge them yourself. A couple of hours on a saturday...hardest part is removing/reinstalling them.
Old Nov 20, 2012 | 09:38 PM
Easily done in the car. Remove Y-pipe is 4 bolts plus however you have it slipfit to the cat.
Measure it up and start grinding away. Remove the O2 if you are worried about damaging it somehow.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
aaron7
Aug 17, 2016 06:02 PM
Polo Z03
Sep 10, 2015 06:43 PM
kyleb24
Aug 15, 2015 08:24 AM
