I want to do true duel exhaust with headers
Old Nov 14, 2012 | 10:01 AM
V8Broski's Avatar
Car: 1991 Camaro RS
I wanted hedman headers with straight pipes, do they make those for are cars? No Y,X or H pipes. I can get anything cheaper brand new because of my dads garage and my brother knows all about these cars but i just wanted to know what other people have done.
Old Nov 14, 2012 | 10:07 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: I want to do true duel exhaust with headers
Do a search for dual exhaust. It has been done. Easiest way with ground clearance is shorty headers and running pipes down stock location. H or x pipe is recommended for balance and sound.
Long tubes will require going around trans xmember and subframe and it gets low in there. Ground clearance reduced
Old Nov 14, 2012 | 10:51 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Peanut cammed 305 LG4 and straight pipes... Really slow, obnoxiously loud, and with terrible ground clearance. You sure that's what you want?
Old Nov 14, 2012 | 11:51 AM
V8Broski's Avatar
Car: 1991 Camaro RS
Just because i can get a 350 doesnt make a 305 slow. Even a stock 305 is faster then the average car, a 305 isn't as slow as everybody exaggerates. I want it to be obnoxiously loud and with a new cam,lifters,750 Holley double pumper, edelbrock intake and duel cold air intake. Also probably some new gears in the rearend. it should be pretty good for cursing around town.
Old Nov 14, 2012 | 11:52 AM
V8Broski's Avatar
Car: 1991 Camaro RS
And sound pretty good.
Old Nov 14, 2012 | 09:56 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
You're just perpetuating the stereotype of thirdgens here... Obnoxiously loud cars are not as cool as you think. If they're horrendously fast, yes. If they're minutely faster than modern day grocery-getters? Not so much. I cammed my HSR'd 305 and yes it made an impressive amount a horsepower for what it was, but it was not a lot. The only reason I did it, is because I got all the parts second hand for CHEAP.
All that aside, yes it's been done a number of times. As Orr89RocZ said, shorties and down the passenger side will be the easiest and get you the most ground clearance. The pinch over the axle is usually the most trying section.
Hotrodboba400
Dec 10, 2019 07:07 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Jlanz55
Sep 6, 2015 07:28 PM
Accerrito22
Sep 5, 2015 09:34 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
