Headers
Old Dec 31, 2012 | 09:09 PM
al1989's Avatar
Engine: 305 5.0 L
Headers
Hello I have a 1989 Camaro RS with a 305 5.0 L engine the last owner put a Mag flow exhaust I was wounder if I replace the the factory header with some hooker short header will this give me some more hose power what you think I should do I dont what to spend a lot on exchust parts easy bolt ons perfer.
Old Jan 2, 2013 | 05:26 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Headers
Hooker 2055 shorty headers or Dyno Don shorty headers. You're going to spend $350 or so on the headers, more if you get them ceramic or jet-hot coated. Both sets come with a good y-pipe so you will just need to have an exhaust shop make sure everything matches up right (In my experience, most bolt-on stuff still requries a little adjustment).
This "could" free up anywhere from 10-30 hp, depending on the rest of the motor.
Do you require emissions testing where you are? If so, you can only buy the emissions legal versions.
Old Jan 2, 2013 | 05:29 AM
freaky's Avatar
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
Re: Headers
i'm running these with a 3" cat back an they perform great .
http://www.ebay.com/itm/NEW-SHORTY-H...sories&vxp=mtr
Old Jan 6, 2013 | 12:08 PM
FtrSpeedy's Avatar
Car: 14 scion tc/91 camaro rs
Engine: 2.5/ 360 pooch
Transmission: 6spd man/th350
Axle/Gears: na/2.73
Re: Headers
I had a chance with my truck to do the exhaust system first then headers, i had no performance gain from headers, sounded better thats all.
Old Jan 6, 2013 | 03:33 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
Re: Headers
They only have an 1 1/2" primary, the smallest I ever seen. Dyno Don's are 1 3/4" and hookers are 1 5/8", plus they have a flange that requires gaskets that are guaranteed to blow out where as Don's has a ball and socket connection requiring no gasket to fail.
Just saying.
Attached Thumbnails Headers-dons-20headers-20wo-20and
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
