Dual exhaust setup question
Car: 1984 Z28 T-TOP
Engine: 355 Lt1 w/Hotcam
Transmission: TH700R4
Axle/Gears: 3.73 4th gen limited slip
84 z28 350. Plan to run Hedman long tube headers. I want to add an extra cat and 3 in pipe and run them both through a cross flow from Dynomax and then to tips. There would be 2, 3 inch pipes. As long as I run the pipes through the cross flow I should work as a duel. Right???
Btw if it doesn't already show, I know nothing about exhaust. But, I think this could work. Any help would be appreciated. Thanks.
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
Re: Dual exhaust setup question
cross flow as in x pipe? then yes it will still be duals. the x pipe will help with the flow of the gasses.
