Thread size for AIR system exhaust manifold ports?
Car: 1987 Firebird Formula 350
Engine: 5.7 Vin 8 L98
Transmission: R-700 Auto
Axle/Gears: factory
Does anyone know for sure the thread size for the AIR (Air pump system) tubes that screw into the stock exhaust manifolds on a 1987 Formula 350 engine? It looks very close to a US thread 1/2x20 but it might be metric.
I am going to remove the AIR pipes and want to install plugs in the exhaust manifolds for obvious reasons
Thanks.
Thanks. Supreme Member
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Thread size for AIR system exhaust manifold ports?
1/4" NPT , any hardware store . good luck .
Axle/Gears: factory
Thanks for your reply Tom. I tried a 1/4" NPT and it does engage a few threads and may work if I really want to crank them into the cast manifold. My concerns is that I don't want to risk cracking the manifolds (at least not right now) due to the extreame heat/cool cycles. The AIR tube system has a flared end on the tube that goes into the manifold, like a brake line fitting. I also measured the diameter of the nut at each end of the threaded section and there is no taper. These 2 things lead me to the conclusion it is not a tapered pipe fitting. If I find the proper size, I will post it here.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
They're 5/16 inverted flare, which has 1/2-20 straight threads. 1/4 NPT also has 1/2-20 threads but they're tapered.
Unless you could find a 5/6 I.F. plug or machine a bolt to put the seat in it, a pipe plug is probably the quick and easy way to go. Plugs to exist, though. Dorman has one, I believe.
1/4" NPT
This is correct:
5/16 inverted flare
toronto formula
Nov 10, 2015 06:17 AM
transaero
Aug 31, 2015 01:14 AM
knight72
Aug 10, 2015 09:32 PM
