Exhaust offset
Old Jan 14, 2013 | 10:59 PM
Jake_92RS's Avatar
Car: 1992 Camaro RS, 2012 Camaro SS 45th
Engine: L03 305 TBI V8, Blown 6.2L LS3
Transmission: 700R4, TR6060
Axle/Gears: GM 7.6" 10 Bolt 2.73
Exhaust offset
I just installed a flowmaster 3" system on my 92 Camaro RS, everything fit fine and it looks great and sounds great, only 1 small problem that needs fixing. The exhaust tips are a little bit offset on the back of my car, you might be able to tell from the picture, is there anything i can do to set them evenly from the sides of the car?
Old Jan 15, 2013 | 03:48 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
Re: Exhaust offset
since you can't really move the whole works over to the passenger side thanks to the spare tire well, the best bet would be to take off the driver's side tailpipe and cut about an inch off between the muffler and the bend.
Old Jan 15, 2013 | 10:04 AM
2007xl50's Avatar
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
Re: Exhaust offset
This is not a bad idea or of you have room see if you can pull the one tailpipe out some, but leave enough pipe in the muffler to clamp. It does not look bad in the pic.
Old Jan 15, 2013 | 10:08 PM
Jake_92RS's Avatar
Re: Exhaust offset
I would do this, but on the left side tail pipe is where the hanger is for the pipe and the muffler, if i moved it, it won't hang properly. I'm thinking my best bet it to try and move the right pipe out a little bit more so they look even, this might mean buying an extension or something like that, I just have to hope the spare wheel well doesn't get in the way too much. Any other suggestions?
Old Jan 16, 2013 | 04:14 AM
novaderrik's Avatar
Car: 86 Camaro
Re: Exhaust offset
modify the hanger.
Old Jan 19, 2013 | 08:45 AM
Re: Exhaust offset
That's how it came, stock.
Because of the way the underside of the car is made, we're somewhat sutck with it.
It is only about an inch or so difference; all but imperceptible to anyone who doesn't already know about it. A bacterium on a gnat's a$$ in the grand scheme of things, with no functional consequences whatsoever. I'd suggest leaving it alone and moving on to things that DO matter.
Old Jan 19, 2013 | 12:40 PM
basshead208's Avatar
Car: 86 IROC Z28
Axle/Gears: posi 4 disc 2.73
Re: Exhaust offset
try this,
Old Jan 19, 2013 | 01:31 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: Exhaust offset
Originally Posted by basshead208
Thats just wrong.
Old Jan 19, 2013 | 01:39 PM
Car: 86 IROC Z28
Re: Exhaust offset
Originally Posted by Johnny Blaze
Thats just wrong.
nope just different. straight out is just too common.
Old Jan 19, 2013 | 01:51 PM
Car: 1971 Camaro
Engine: 427
Re: Exhaust offset
Tips out the side, like factory 70's is fine, when you can just see the tips.
Tips out the side when the entire exhuast is hanging below the bumper just looks poorly installed.
Old Jan 19, 2013 | 02:19 PM
Car: 86 IROC Z28
Re: Exhaust offset
the piping is all where the muffler would be and just the tips exit the sides nothing hanging below the bumper its just the camera angle.
Old Jan 19, 2013 | 02:40 PM
Car: 1971 Camaro
Engine: 427
Re: Exhaust offset
I'd like to see a pic from a better angle.
Old Jan 19, 2013 | 02:56 PM
Car: 86 IROC Z28
Re: Exhaust offset
you dont see the piping unless you duck down
Old Jan 19, 2013 | 03:01 PM
Car: 1971 Camaro
Engine: 427
Re: Exhaust offset
Still don't care for the big tips like that, but if you like it its all good I suppose.
Old Jan 19, 2013 | 03:11 PM
Car: 86 IROC Z28
Re: Exhaust offset
3.5" tips on 3" exhaust
Old Jan 19, 2013 | 03:18 PM
Car: 1971 Camaro
Engine: 427
Re: Exhaust offset
What I meant was those big straight tips at an angle. Where you see the whole side of the tip, but no worries, if you like it cool.
You got dual 3" pipes? Did you build the whole exhuast?
Old Jan 19, 2013 | 03:30 PM
Car: 86 IROC Z28
Re: Exhaust offset
305 TPI to 350 TPI swap, Headman Headers into 3" stock routed to removable spun metal bullet cat then 3" back to the piping that replaces the muff and into tips. no muffler, not too loud until WOT. Im building a 4 bolt full forged 363 with single GT-45 turbo and a 700r4 manual VB on a 12 bolt. Wont do slicks, just a mean mean street car. And with a manual boost controller in the car I can launch on motor then crank the boost after second gear. Im as far as the block work and heads right now and dont expect to be done for another year or two. No hurry
zapr
Jul 27, 2018 06:03 PM
PurelyPMD
May 5, 2016 04:57 PM
david068513
Sep 18, 2015 10:36 AM
brockerboy
Wheels and Tires
Sep 17, 2015 03:59 PM
rb85TA
26
Sep 14, 2015 10:29 PM
