Rusted manifold bolts and a torch
Car: 1986 TA
Engine: 5.0 lg4 carb
Transmission: 700r4 auto
Have engine all apart for cam change. Figure ill do headers while in there too. Manifold bolts rusted in. What's best way to remove? Can you get a torch in there?? Bolts have been soaked with PB nut buster spray..
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: Rusted manifold bolts and a torch
are you sure its not the metal tangs holding you up? from the factory they install the bolts, then bend 2 edges of a tang so that the bolt wont unloosen. sometimes theyre difficult to see. look real carefully. take a flat screwdriver and bend the tangs out. the bolts should unloosen then.
Car: 1983 Camaro
Engine: 385 stoker
Axle/Gears: 10 bolt Torsen Posi 3.73 ratio
PB blaster , torch and a lot of patients is all you can do. Go easy a little at a time. If its not budging, don't crank it. They WILL snap if you aren't careful.
Car: 1986 TA
The snapping is what I'm affraid of. That's why I was asking about Torch.. Can't get to car right now. My cars portable shed still under 4 feet on Snow. Nothing new for New England..
Engine: 4++,350 & 305 CIs
If you don't mind the heat, fire it up and get it warm. Shut it off. That can help get them loose.
ambainb
Apr 25, 2016 09:21 PM
Dialed_In
Aug 20, 2015 01:45 PM
