Aluminum cat back...can it be done???
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Hey guys I have a strange question... I was wondering if it were possible to run an aluminum cat back? I know the exhaust gases would be substantially cooled after it exits the y-pipe so the risk of melting would be none existant. I know some of us, much like my self are weight ****'s so I thought I'd ask. I'm thinking of a 3.5 single set up with my LT383. So the question stands...can it be done????? lol
Re: Aluminum cat back...can it be done???
I do actually, there's a welding shop here in town that has good access to some.Also I've found that ebay has a ton of Mandrel bent stuff in aluminum thin wall tubing.
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Cool, I guess it would work.
Any idea what the weight difference is?
Like you said, heat should not be a real issue, probably the only issue would be strength. I would think aluminum would get dented up pretty quickly.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Titanium is the thing for lightweight exhaust.
Car: 1971 Camaro
Engine: 427
Engine: 383 Carb
Transmission: 4L60
You underestimate the availability of titanium tubing on the surplus market.
Car: 1985 Volvo turbodiesel
Engine: 1989 305 TPI in the Volvo
Transmission: 1990 700r4
Axle/Gears: 3.73 Dana 30
Aluminum will take the heat no problem after the cat. Just no exhaust manifolds
Car: 1971 Camaro
Engine: 427
Again, I'd be interested to see what the weight savings would be.
Engine: 383 Carb
Transmission: 4L60
Probably not alot of weight savings, few pounds, If you have access to free or really cheap tubing and can weld/join it, go for it, I wouldn't spend much money on it, the bang for buck ratio is probably not good, but adding lightness is always good
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
Titanium exhaust tubing is actually quite cheap on the market these days. No where near as cheap as steel but definitively do able. I have seen 3" x 4' lengths of thin wall tubing for less than 200$.
Problem is its extremely difficult to weld correctly, is reactive to air and oxygen at temps over 800º. Need specific shielding gas, as well as you need to weld in an untraditional way when compared to alum and steel. I have seen titanium welded in a vacuum for these reasons. I have also seen TIG torches liquid and water cooled for welding Ti.
Aluminum is perfectly fine as an exhaust, I have seen many systems done out of aluminum. Its sounds killer too compared to steel.
Just an FYI alum is more brittle than steel and even more so at high temps. You can not use weld on hangers. You will need to use special hangers band clamped to the exhaust.
Also due to oxidation issues you will need to coat it.
@danclemts: How do you add lightness? If you add something you are almost always adding weight. And It is quite a bit of weight savings, We weighed a Aluminum cat back exhaust and it was under 20lbs including the stainless muffler. When a OEM system can weigh up to 70lbs.
Car: 1971 Camaro
Engine: 427
Thats compared to a stock cat back.
If its a road race car, are you even required to run a full exhuast and mufflers?
Car: 1985 IROC-Z
Engine: 355
The question is can you weld aluminum or have your exhaust welded. A bunch of clamps or a couple of 4' true dual straight pipes with mufflers on the end are not cool, and tasteless.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Aluminum isnt cheap but very light weight. I could easily see 20-50 lbs depending on type of system.
My dual 3" is off the car at the moment. Let me weigh it and by looking at what alumium weighs i could estimate the difference. My 3" steel is extremely heavy.
Adding lightness is an old car guy thing, i think it was Colin Chapman who coined it (Lotus) 50 lbs is substantial, I'm in the middle, got 2 -2 1/4 pipes going into a single 3" into a flowmaster
Yes I can have it welded in large sections. I want it to be a full catback as I would still like to reuse my Aerochamber muffler. The only major clamps I could see would be the one from the y-pipe to the I-pipe then from the end of the I-pipe just before the bend over the axle. My only concern after that would be having a flange made to bolt the muffler to the pipe.
Well my quest continues for the aluminum catback...I found a pretty nice kit on ebay today that comes with all the bends needed to create the catback and then some. It's a good price too. I'm going to write the seller to see if he has 3.5 straight tubing in a 36 inch length for the I pipe. Here's the kit in question...
http://www.ebay.com/itm/3-5-mandrel-...d6a249&vxp=mtr
Actually I just found another seller that sells 36inch staright tubing for a fairly decent price too..
http://www.ebay.com/itm/3-5-Aluminum...item53f50a303c
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
I dont think there is any issue with aluminum exhaust pipes - other than the temperature of manifolds excluding them from that use.
Titanium is really light, but very hard to weld as other have mentioned - Arapovic sells them for imports, some systems top $8k.
The one material I haven't heard mentioned is inconel steel tubing, like NASCAR teams use for their headers - really thin wall, light, and pretty easy to weld (definitely not as hard as Ti). Just don't know if you can get it in 3" or larger. Don't forget that you will need a muffler - that is a heavy chunk of metal.
Car: 89 Iroc-z
Transmission: TH400
Inconel would be way expensive. Aluminum is ok, i just learned some guys use that for downpipes on turbo cars! Yikes that is very hot service
[Sold] Flowmaster exhaust system
Night rider327
Oct 9, 2015 09:25 AM
Night rider327
Sep 25, 2015 04:47 AM
