UpnComin gear head...needs help!!
Old Mar 6, 2013 | 12:56 PM
Camaro-King79's Avatar
Engine: 350 bored .040 over
Been taking the wrong approach when it comes to my Camaro..which is my baby.. I've let a couple of different so-called, want to be mechanics try their luck at fixin my car, only to be burned in the end result and often my pockets!! So now I'm taking matters into my own hands, n I need all the help I can get from my new thirdGen F-body techies..bc Ima newby et all this.
My problem is that my 90 Camaro RS originally came with 3.1L v6 MFI ..well I replaced tht motor wit a used motor(tht was totally bad from tha start!) tht I gt from tha mechanic, only fo it to blew up on me while driving it for only tha 3rd time. Since then I've replaced that bad motor with a new 350 engine..block fully rebuilt, n freshly bored .040 over..bt tha previous mechanic had cut a lot of tha wires under my hood, so now my dash is completely useless...I can't read tha speedometer..rpms..gas..or temp gauges? Is there away I cud rewirer these back up without havin ta buy a new wiring harness? If so, how? n wat types of wire can I use ta do so..or where can I buy tha rite kind? Also I've already bought a replacement steering column for my car, bt how do I gt tha air bag steering wheel off n the column out to put n tha new one? HEEEEELP PLZ
Old Mar 6, 2013 | 01:15 PM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
Re: UpnComin gear head...needs help!!
Du solltest dir ein Werkstatthandbuch mit den Schaltplänen zulegen.
Guess you were able to understand that about as well as anybody else trying to read your ghettotalk up there!
You will have to get yourself a factory service manual for your vehicle's build year, because you will need to check out every wiring diagram it offers. You won't be able to find all the right cable colors otherwise.
You can find cables of the right diameter and color at any radio shack, I guess.
Just cut a tiny piece off and take it there. They should be able to give you the correct wires. And you'll need lots of wires... and colors.
Be extremely careful with that airbag. Search the boards for the procedure try not to get killed while removing the thing.
Old Mar 6, 2013 | 03:27 PM
Don't kno tht German ghetto slang u wrote at tha top...bt I appreciate tha direction of help you've pointed me n. thankx
Old Mar 6, 2013 | 03:28 PM
2007xl50's Avatar
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
Yes what he said and how does this thread have anything to do with exhaust? this should be is general tech. I'm not a very good speller, but my God man, I could not read the post.
Old Mar 6, 2013 | 03:33 PM
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
I don't totally understand what you're asking either but it sounds like you need another wiring harness. I'd look through the classifieds on this forum and check the local junkyards to see if you can find one complete harness and then do as NCC-2569 suggests and get yourself a manual.
Old Mar 6, 2013 | 03:35 PM
Richboll's Avatar
Engine: 305 TBI
And as 2007Xl50 says...this is in the wrong forum
Old Mar 6, 2013 | 03:54 PM
Fellas I'm new at this and I'm still trying to figure this site out as I've never been on one of these before...I can't seem ta figure out how to find n fill out fields,etc.. all I have is this iPad to wrk with for now so maybe I'm unable to see or use all features on this site so bare with me. Basically as you've all guessed it, I'm having sum wiring issues, as well as a steering column issue...especially since im new to tha DIY field.any tips ta help use this site mo effectively we'd b great..thanks to all who've responded
Old Mar 6, 2013 | 04:12 PM
If I was to buy a new or used wiring harness, so I can have my dash back in order, wud I need a engine or electrical wiring harness?
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
