oil dip stick and stock exhaust manifolds
Old May 3, 2013 | 12:48 PM
kobrak's Avatar
Car: 1983 Z28 Camaro
Engine: 350 block with original Cross Fire
Ok, I have an 83 crossfire Z with a 350 block................I believe it is a 79 block. I'm running the stock heads and stock exhaust manifolds............
Here is the problem. I cannot get a dipstick into the block as it is located on the drivers side of the block. There isn't even a 1/2 space where the dip stick tube should go. The question is this...............can someone that is running short headers tell me if I changed out to a short header I'd open up some room down below the header to the block?
Old May 3, 2013 | 06:30 PM
Re: oil dip stick and stock exhaust manifolds
Yes; headers, AFAIK ANY headers, cure the problem completely.
Old May 4, 2013 | 03:18 AM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
You jist have to pinch tube.
Old May 5, 2013 | 11:06 PM
kobrak's Avatar
In my case you can't pinch the tube.......remember, the tube changes to the driver side on an earlier 350 block. The one in there right now is crushed, just no room at all.
Old May 6, 2013 | 12:57 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
they moved the dipstick in the late 70's to clear the new stupid exhaust manifolds they were using. i can't see why a set of headers wouldn't open things up enough to get a dipstick in there..
Old May 8, 2013 | 08:12 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Headers will fix it.
But you can "pinch" the tube. I have done it, I know. I did remove the inner portion of the heat shield on the manifold and I slightly ground the manifold in that spot.
You can also get an expensive flexible dipstick. But if you are contemplating headers, dont even think twice, go headers.
Reddeath210
Oct 6, 2015 08:20 AM
transaero
Aug 31, 2015 01:14 AM
Navy8125
Aug 21, 2015 09:32 AM
timonator
Aug 11, 2015 09:56 PM
the_nikfive
Aug 11, 2015 02:46 AM
