Side pipe help
Old May 21, 2013 | 08:56 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Transmission: Built T5
Axle/Gears: 3.73 Posi
Side pipe help
I'm currently building a 383 for my 91 RS. The plan for the exhuast is to use hooker longtubes (2210's) and run a muffler off each header that just connects to the 3 bolt flange, then run from that down each side of the car (hidden, not outside the body) and kick it out in front of the rear wheels. Anyone who has done this, did you have clearence issuses? I also have lowering springs im putting on to drop the car 1.5"
Old May 21, 2013 | 09:28 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: Side pipe help
Check out the dual exhaust picture collection: https://www.thirdgen.org/forums/exha...l-exhaust.html
It will probably answer your questions and then some. Some members have posted pictures of similar setups but their ground clearance is down to maybe 3". I have run dual 2.5" exhaust with a pair of Hooker longtubes and I feel the only way to do that was with a resonator, one that is only one inch larger in diameter than the pipe's diameter. I have heard the option of cutting off the bottom of the rear seats and welding a flat steel plate in it's place and that gives you room to put a real muffler on each side.
Old May 21, 2013 | 09:31 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Re: Side pipe help
Awesome, I'll check it out, Thanks.
Terrell351
Jun 13, 2021 01:13 PM
hectre13
Sep 8, 2015 03:38 PM
transaero
Aug 31, 2015 01:14 AM
chubsworth
Aug 26, 2015 02:34 AM
db057
Aug 22, 2015 08:17 PM
