Exhaust Help: Cat delete and leak
Old Jul 1, 2013 | 04:59 PM
JBarr83's Avatar
Car: 1989 Firebird
Engine: 305 5.0L
Hello, so I have an 89 Firebird with the 5.0 305 Throttle Body, and where I live I don't have emissions. I recently bought a magnaflow exhaust catback and just ended up cutting off the cat because it leaked anyway. I was wondering what the metal tube running into the cat is and how can I get rid of that? Also, I think either the Y pipe or manifold is leaking on the passenger side. What is the best way to check that out or replace it? Pretty cramped in there.
Old Jul 1, 2013 | 08:14 PM
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
Re: Exhaust Help: Cat delete and leak
passenger side cylinder head, that tube is clamped to the back of the head. It's the tube running from your A.I.R. pump to your cat to heat it up quicker, but since you don't have emissions you can rip it out.
Old Jul 2, 2013 | 02:50 PM
JBarr83's Avatar
Car: 1989 Firebird
Engine: 305 5.0L
Okay, thanks a lot. I'm probably going to rip out the AC because it just doesn't work anyway... and the smog pump, which is right below and to the right of the AC compressor correct? I can just take both of those out completely and that's that? Just making sure I don't mess something up. From reading I'm going to need an AC delete pulley and I don't need the smog pump pulley. I can either reroute or take the internals out and just use the shell.
Old Jul 2, 2013 | 03:39 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
https://www.thirdgen.org/serpentine
Old Jul 3, 2013 | 08:25 PM
Dakota W.'s Avatar
I bought an idler pulley off a saturn vue and replaced mine with that, as well as got a shorter belt. My smog and A/c are removed. The smog pump will seize and destroy your belt if you leave it on and not hooked up to anything.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
LittleFranks
Sep 17, 2015 12:22 PM
ambainb
Aug 29, 2015 12:43 AM
BlackphantomZ28
Aug 21, 2015 07:12 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
