Dual Exhaust
Old Jul 13, 2013 | 02:24 AM
88IROCZ_78's Avatar
Car: 1988 Iroc Z
Dual Exhaust
Do you need to change the transmission cross-member when installing a true dual exhaust system? I've found this one on Summit Racing.
http://www.summitracing.com/parts/su...s/?prefilter=1
Old Jul 13, 2013 | 07:15 AM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
Re: Dual Exhaust
thats not for your car, depends what mods you have and how you want it to run. check out the dual exhaust sticky
Old Jul 13, 2013 | 11:33 AM
Z28/ZR1's Avatar
Re: Dual Exhaust
You can use your stock cross member, although you will need to re-enforce the area where material is removed for clearance.
Old Jul 16, 2013 | 09:11 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Re: Dual Exhaust
I had to cut on the passenger side frame to make room for the pipe.
Hotrodboba400
Dec 10, 2019 07:07 PM
customblackbird
Oct 1, 2015 04:30 PM
Camaro_383
Sep 11, 2015 11:28 PM
Djmathis123
Sep 8, 2015 08:42 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
