Exhaust Rattle Issues Convertor?
Car: 1986 305 IROC Z
Engine: 305 tpi
My car has been pooping a bit when I rev but has also developed a fairly bad rattle now it is spewing small silver flakes out the tail pipes? From the sound of it the covert or has bit the dust. Is it possible to just replace this piece? Would a new cat back be better I just have two resonated Monza tips on the back of my car at the moment with no muffler.
Car: 86 iroc, 02 v6 camaro
Engine: 350 HSR, 3800 V6
Transmission: T56, WCT5
Axle/Gears: 9in 4.11 posi, 3.23 LSD
Re: Exhaust Rattle Issues Convertor?
sounds like a 'vertor. take a rubber mallet and give the cat a few taps to see if you can hear it rattling. i cant think of anything else that would cause metal to come out of the exhaust
Car: 88 Camaro
Engine: L98 350
I'm on my fifth converter. Tried Catco and now Marmont. I finally unhooked the airpipe to the middle of the converter and hope it helps. I'm thinking the air feed overheats the second cat. bed, softens the adhesive, and loosens it up. Real nasty rattle with that. Next step is to put a pipe through it.
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
I converted my single Catco to dual Magnaflow converters a couple of years ago with no problems since.
Street Lethal
Apr 30, 2019 12:14 PM
