Hedman question
Old Nov 24, 2013 | 03:14 PM
Clausoe's Avatar
Hedman question
Hi,
Does anyone have experience with Hedman 68470 on 305 86 Firebird, leakage or clearance issues?
I know from other threads many recommend Dyno Don or Hooker but for me to get those in Norway is just to expensive.
Old Nov 24, 2013 | 05:56 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: Hedman question
Great headers. Good bang for thr buck.
You should have no problems.
Old Nov 24, 2013 | 05:57 PM
Car: 1971 Camaro
Engine: 427
Re: Hedman question
Old Nov 25, 2013 | 02:47 PM
Clausoe's Avatar
Re: Hedman question
Ok, sounds good, thanks
Old Jan 5, 2014 | 10:21 PM
99olo's Avatar
Car: 1982 Pontiac Trans-AM
Engine: 283
Transmission: Saginaw 4 Speed
Re: Hedman question
For that price, you could get the full length headers.
Old Jan 7, 2014 | 12:13 PM
a62belair's Avatar
Car: 88 Firebird, 87 Formula
Engine: 2.8, 5.0
Transmission: both 700R4
Axle/Gears: 3.42,3.45
Re: Hedman question
I used red hi-temp silicone on all my connections to the headers- at both sides of the (yes) paper gaskets, and at the y-pipe (aluminum) gaskets. I have had no leaks so far... I've found the header bolts slightly loose- but still no leaks or burning of the paper gaskets...
Old Jan 7, 2014 | 03:33 PM
racerx520's Avatar
Re: Hedman question
what kind of gaskets did you use at the heads to headers? just curious cuz i used aluminum gaskets and sometimes i think i hear a leak, but i was told that headers just make a "chugging" sound. Its only at low RPMs though.
Old Jan 7, 2014 | 03:36 PM
Guest
Guest
Posts: n/a
Re: Hedman question
Link to said alum header gaskets?
All I can find are the crappy paper 1s.
Frozer!!!
Jan 19, 2024 04:55 PM
hectre13
Sep 8, 2015 03:38 PM
downsouthboy
Aug 29, 2015 11:29 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
