Shooting exhaust flames question!
Hi guys, is there anything that I can put on my bumper to stop exhaust flames from burning it up? I would like to install a system that shoots flames and before I do it I was just wondering if there was anything I could put to shield it.
Thanks very much!
Thanks very much!
Car: 85 Silver Iroc, 79 Camaro
Engine: LB9, 500+ ci BBC
Transmission: 700R4, th400 with brake
Axle/Gears: 3.42, hand made 40 spline 9"
Re: Shooting exhaust flames question!
DEI makes a sticky backed foil type pad that you can stick to almost anything and it'll reflect the heat away.
http://www.designengineering.com/cat...s/reflect-cool
Car: 1989 IROC-Z / T-Top -1987 GTA
Engine: 305 (LO3) _350 (L98)
Transmission: 700R4 _ 700R4
Axle/Gears: 2.73 L.S. - ???
it is a bit harder to put "afterburners" on an injected car, you almost need to inject raw fuel into the pipes because you can not just pump the carb and load it up that way ... one way i did see it done was to have fuel injected into the pipe after the the converter with a piece of steel line with a check valve on it, i would guess the return fuel line would give enough pressure to do the job, as it should just take a few drops
