CA Smog | Going legit?
Old Feb 5, 2014 | 07:46 AM
mu33rto's Avatar
Car: 1992 RS
Engine: 305 5.0L V8 TBI
I smoged my car last year when I acquired it even though the catalytic converter was hollowed out it passed.Took it to a magical place. Now my tags are up this March and need to re smog my 92 Rs Tbi 5.0L camaro. The smog shop fee increased almost %100.00 percent since last year.
My car currently puffs white smoke each time I'm at a red light this is the main reason why I want to add all the emission stuff back. It's making me think if I want to keep my Camaro for a long time I should go legit right? Since these type of places will all ways going to increase their fee.
Old Feb 5, 2014 | 04:30 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
Re: CA Smog | Going legit?
I say go legit.
Old Feb 5, 2014 | 07:39 PM
Zane M's Avatar
Car: 1991 GTA
Engine: LB9
In the long run it will be much less headache to go ligit.
However, it sounds like you have a bigger issue with the smoke.
I can't think of any place in the country that will even test your emissions if you are blowing smoke-automatic fail
Old Feb 6, 2014 | 01:33 PM
mu33rto's Avatar
Car: 1992 RS
A few months ago it didn't smoke. I reused old oil and old spark plugs. I messed with the timing a bit. Going to do a tune up and see if that help. I just saw a carb approved catalytic converter for $170.
Old Feb 6, 2014 | 06:28 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
I think in CA now only a licensed installer can install cats legally and with a bunch of paperwork too. ???
Old Feb 6, 2014 | 08:43 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
my cars puffing too.i was wondering if reinstalling the cat would 'burn'the smoke off before the tailpipe.
Old Feb 7, 2014 | 09:13 AM
mu33rto's Avatar
Car: 1992 RS
Hopefully they don't ask to much to install it. If they do I will just get the direct bolt on.
Zenish: I was thinking the same.
Old Feb 7, 2014 | 09:23 AM
mjdavis68's Avatar
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
Im certain that your valve stem seals have Hardened and this causes the symptoms yall are speaking of. Its a cheap fix if you know how to do it on the car. Ive done it a few times. look into it....
Old Feb 8, 2014 | 01:29 PM
mu33rto's Avatar
Car: 1992 RS
I few months ago I had the engine pulled in order to change the rear main seal. Should of done it then.
Old Mar 1, 2014 | 01:46 PM
Jono4820's Avatar
Car: 1991 RS
Engine: 350 TBI
Axle/Gears: 3.08 lt. slip
re used old oil...really??
Old Mar 1, 2014 | 06:50 PM
mu33rto's Avatar
Car: 1992 RS
I originally was running some Amsoil Z-ROD for a couple of weeks. I took it out in order to add cheaper oil and some sea foam product. No reason to throw away money.
jaridjohn
Oct 5, 2015 07:01 AM
wstephan96
Sep 25, 2015 04:28 PM
