2.5 or 3 inch exhaust?
Old Feb 24, 2014 | 09:12 AM
Laugh-Master!'s Avatar
Car: 84 camaro berlinetta
Anyone notice a distinct sound difference between these sizes? Stock 305 by the way. Sorry if this had already been covered. My search on my app isn't working.
Old Feb 24, 2014 | 09:49 AM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Re: 2.5 or 3 inch exhaust?
3" is going to be a bit louder and have a deeper sound.
With a 305 (or larger), you do need a 3" exhaust (from the y-pipe on back), otherwise you have a backpressure problem.
Old Feb 24, 2014 | 10:06 AM
That 3 inch deep sound is what I'm going for. I'm buying a summit racing cat back that's all 3 inch but has 2.5 inch tailpipes.. Would u still get the deep sound or no?
Old Feb 24, 2014 | 10:08 AM
Was thinking about maybe going with the summit and replacing the muffler with a MagnaFlow and 3 inch tailpipes..
Old Feb 24, 2014 | 08:24 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
If your saying that the pipe that is coming from the muffler is 2.5 with 2.5 tips.
A 2.5in. pipe leading from a muffler will not sound like 3in. pipes. The 3in. is what gives it the deeper tone. Besides a 3in. opening from behind just looks killer.
Old Feb 24, 2014 | 09:22 PM
Chad85T/A's Avatar
Car: 85 T/A
I have the summit 3" kit on my 305 and it sounds good. I get compliments on it all the time.
Old Feb 24, 2014 | 09:47 PM
Engine: TBI,5.0
Unfortunately this is all Summit had for a 84 Berlinetta.
http://www.summitracing.com/search/y...le-in-dual-out
Old Feb 25, 2014 | 06:51 AM
Does your summit racing 3 kit have 3 inch or the muffler too or just the intermediate pipe?
Old Feb 25, 2014 | 07:23 AM
Chad85T/A's Avatar
Car: 85 T/A
Mine has the 3" intermediate an 2.5 " exit. It's the SUM-680023 kit, 5.0-5.7.
Old Feb 25, 2014 | 07:38 AM
Yea that's the one in looking into. Any chance you got a sound clip? Do you have the stock manifold? Cat?
Old Feb 25, 2014 | 09:05 AM
Chad85T/A's Avatar
Car: 85 T/A
I'm running the manifolds with no cat. I do have a sound clip, but I don't know how to paste it here with my phone.
Old Feb 25, 2014 | 09:15 AM
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
Sound changes based on the opening, that's why you see hondas running around with huge 4"+ pipes out the back. Going to a 2.5" exit isn't going to be the same as a 3" exit.
That's exactly what I would have. Is there anywhere on the Internet that has it? Can you use the attachments button on the reply menu in the app?
Old Feb 25, 2014 | 09:16 AM
Makes sense.. Wish the summit kit came with 3 inch out but for some reason it's not.
Old Feb 25, 2014 | 09:51 AM
Chad85T/A's Avatar
Car: 85 T/A
Laugh- master, if you'll send me your email I'll send you my sound clip.
Old Feb 25, 2014 | 09:56 AM
Pm sent. Thanks
Old Feb 26, 2014 | 08:56 PM
85ttopsz28's Avatar
Car: '85 camaro z/28
Axle/Gears: stock
if you have a stock 305 you don't need any bigger than 2.5in
Old Mar 10, 2014 | 02:21 PM
Ghettobird52's Avatar
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
What if the Tips themselves are 3" but the pipes leading from the muffler are 2.5" ? Would you still have the loud(er) 3" sound from the 3" opening tips? Or no because of the 2.5" Pipes actually leading from the muffler.I'm soon to be redoing all of my exhaust and i'm thinking of changing over to the Flowmaster 17233 Catback system (80series crossflow with 3" inlet & dual 3" outlets) and want to know if it will be louder because of actual bigger sized pipes in between the tips and muffler. Anyone with some knowledge or advice would be greatly appreciated.
Also right now i have a 2.5" pipe running in between my cat and muffler, im going to change to 3" all the way back from the cat, will this make it any louder as well? So basically my new system is going to be 3" pipes from the cat back ( as right now it goes 2.5 to muffler, to dual 2.5 tips.)
thanks all!!!
Old Mar 14, 2014 | 09:56 AM
82crossfire305's Avatar
Car: 1982 Trans Am
Engine: LU5 CFI
Transmission: TH-200C
I thought the 3'' exhaust on a stock engine was basically robbing you of torque? from my understanding and what i read up on in the past that unless your engine produces enough power to sustain the larger diameter exhaust, the back pressure wont "be there" I could be wrong i just know how to work on cars not modify to professional standards.
Old Mar 14, 2014 | 10:27 AM
Car: 1982 Trans Am
Engine: LU5 CFI
well found the the sticky and basically look at the article labeled. "everything you ever wanted to know about backpressure"
Old Mar 14, 2014 | 12:03 PM
I don't want back pressure, I want exhaust velocity or scavenging , but that's neither here nor there , I'm just wondering what sounds going to be like changing my pipes diameter.
Old Mar 15, 2014 | 05:04 PM
els-'s Avatar
This is shorty headers into a 3 inch single pipe, gutted cat, and one of the flowmaster rip offs with 2.5 out.
86 trans am
Old Apr 3, 2014 | 05:27 PM
1991_RS's Avatar
Car: 1989 Formula Firebird
Engine: Swapped 350 TPI speed density
Axle/Gears: 2.73 (soon to be 3.42)
FWIW, my 99 'bird (winter car) has the 3800 V6 with 3" pipes and at an idle, it sounds as deep as a 350. But when you wind it up, it still sounds like the V6.
Bottom line, bigger = deeper, but it's not going to make a small, 200 hp motor sound like a 1000hp drag car.
Hotrodboba400
Dec 10, 2019 07:07 PM
customblackbird
Oct 1, 2015 04:30 PM
ericjon262
Sep 11, 2015 06:07 PM
89fast5oh
Sep 8, 2015 09:55 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
