popular long tubes for 3rd gens?????HELP!!!
Old Mar 3, 2014 | 08:21 PM
Austin90RS's Avatar
Car: 1990 camaro rs
Engine: LQ4 350 4 Bolt
Axle/Gears: 4:10 posi
Hi,after a recent motor swap I come to realize my summit down pipe I had setup with my old vortec 305 no longer fits with my 79 350 in the car.Im looking to setup duals with long tubes, what are some popular long tubes that will have little to no clearance issues and what are some to stay away from? thanks
Old Mar 3, 2014 | 09:16 PM
JacobIroc's Avatar
Car: 92 RS 25th Anniversary
Engine: 305 TBI -> 305 TPI
Transmission: T5/T56
Axle/Gears: 3.08 - 3.73+ soon
Re: popular long tubes for 3rd gens?????HELP!!!
It's my understanding that all longtube headers require some modification or bullshit to fit.
Old Mar 4, 2014 | 12:51 PM
Guest
Guest
Posts: n/a
Theirs only like 4-5 brands and 1-2 are knock offs.
-just pick 1
Old Mar 4, 2014 | 05:06 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Wow I bet that vortec 305 was faster than a 1979 anything... And I'm really confused about why the setup you had wont fit. SBC's are externally identical for the most part, at least as far as exhaust port location is concerned.
None that I know of fit in painlessly. But none of the big name brand ones are bad. Hedman and Hooker are probably the most popular. The ground clearance with duals is going to be a nightmare, though. I'd suggest you go a different route. But if you want to have that low compression 70's chevy + glasspacks pulpwood truck sound (kind of unavoidable as you wont have the ground clearance for a real muffler) then you're in luck. Loud n slow!
Frozer!!!
Jan 19, 2024 04:55 PM
italiano67
Dec 11, 2016 09:21 AM
tricky1
Aug 23, 2015 01:17 PM
86iroc z Z28
Aug 21, 2015 10:37 PM
beast94
Aug 20, 2015 06:44 AM
