Mufflex y and umi ta reloc. crossmember, any issues?
Old Mar 19, 2014 | 12:24 PM
sheikss's Avatar
Car: 88 Trans Am GTA
Axle/Gears: 12 bolt 3.73
Any known issues with the umi crossmember and mufflex y pipe?
Old Apr 23, 2014 | 08:54 PM
sheikss's Avatar
Re: Mufflex y and umi ta reloc. crossmember, any issues?
So no one here has ran this setup?
Old May 6, 2014 | 05:58 PM
ziggy89's Avatar
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
ive heard they don't work with the spohn cross member which is the same kind of deal.
ill let you know how mine turns out but im also cutting mine up so I can use cutouts.
Old May 9, 2014 | 06:26 AM
sheikss's Avatar
Looking at pictures of the mufflex y it appears it won't work. Kinda pissed about that but what can I do. Looks like I will be going back to the stock setup for the crossmember and torque arm mount.
Old May 9, 2014 | 07:57 AM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
I took mine to a muffler shp and took some different angle bends and the muffler guy cut out a section and had it fixed in less than half an hour. Just have some different bends ready and it is not a big problem.
Old May 9, 2014 | 05:43 PM
sheikss's Avatar
You wouldn't happen to have or be able to post a pic would you? Just want an idea of what bends I would need and how it will turn out.
Old May 22, 2014 | 10:26 PM
ziggy89's Avatar
Engine: 383
no way is my mufflex y going to work with my spohn torq arm/crossmember. hits the cross member itself and the drive shaft loop.
Old Jul 19, 2014 | 04:05 PM
iroc90dfi's Avatar
Car: 1990 IROC-Z
Engine: 355 TPIS Mini Ram, Vortech R-Trim
Axle/Gears: 3.73 Strange S60
Mufflex y-pipe and the UMI torque arm cross member will not work. I just got done trying it. I am thinking of taking the y-pipe to a shop and see if they can make it work. any other suggestions?
Old Jul 19, 2014 | 04:36 PM
sheikss's Avatar
I am going back to the stock crossmember.
J-money
Jan 4, 2019 09:45 AM
TheTraut88
Sep 11, 2015 05:16 AM
383cam
Sep 9, 2015 06:01 AM
UMI Performance
Sponsored Vendors
Sep 4, 2015 09:22 AM
UMI Sales
Sep 4, 2015 08:39 AM
