Edelbrock header y-pipe question
Old May 8, 2014 | 10:30 AM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
When I bought my car it already had edelbrock shorties on it. My y-pipe is kinda leaky but it looks like a stock y-pipe but i'm not sure. So I am wondering if there are any y-pipe options out there that fit the edelbrock headers
Old May 8, 2014 | 10:36 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: Edelbrock header y-pipe question
I make a replacement Y-pipe for some of the Edelbrock headers.
I need to know which ones you have,
A picture would do.
Old May 8, 2014 | 10:41 AM
Car: 91 Trans Am
Engine: 355 TPI
i believe they are the TES ones. the header on the passenger side has the pipe run over the top from cyl 2 towards the rear of the engine and then down to the collector. I'll snap a pic if need be. How much do you get for those y-pipes?
Old May 8, 2014 | 11:04 AM
Dyno Don's Avatar
You have a PM
Old May 7, 2022 | 02:07 PM
imlittlericky's Avatar
Car: 88 IROC-Z
Engine: 5.7l gen1 small block
Axle/Gears: B/W 9 bolt w/3.73 yukon gearset
Hey Don....I've got an 88 iroc with 15,000 miles on it and the y pipe is the only rotten metal on the car. If you're still making this y pipe I'd appreciate some more info. Thanks
Old May 18, 2022 | 03:35 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Ricky,
Post here: https://www.thirdgen.org/forums/exha...nt-y-pipe.html
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
beastin91rs
Oct 9, 2015 07:38 AM
hectre13
Sep 8, 2015 03:38 PM
Out-Cast
Aug 22, 2015 07:49 PM
redmaroz
Aug 16, 2015 11:40 PM
