help!!!in exhaust shop 2210 can i fit dual 3" to third member?
Old May 20, 2014 | 06:43 PM
chevyredneck8's Avatar
Car: 88 Iroc Z
Engine: L98 350
Transmission: 700 R4
I have a 383 procharged irocz with hooker 2210s. My originally exhaust plan was run dual 3inch lines from the collectors to under the 700r4 crossmember then connect them together with 3inch y 4"outlet. Then another y connected to that, with a dump valve and the other side going to the factory exhaust.
The installer thinks he can only fit 2.5 inch without it being a serious ground clearance issue on the drivers side coming along next to the transmission and he doesn't think I need a bigger exhaust which I believe I do especially if I raise the boost later.
Is anyone running stock height and 3inch along side the driver side without major clearance issues?
I am aware ill need to be very mindful of potholes, dips and speed bumps. But I wanna get a fellow third gener's input before I tell him to run 3inch.
Thanks ahead of time!!! and input tonight even if quick would be assume since I have to make a call in the mourning
Old May 21, 2014 | 02:20 PM
Goosehead's Avatar
Re: help!!!in exhaust shop 2210 can i fit dual 3" to third member?
you should consider square tube exhausts, but a dual exhaust is quite a pain in the butt on these cars
Old May 21, 2014 | 11:41 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Oval pipe works too.
I did it
Old May 22, 2014 | 07:13 AM
Car: 88 Iroc Z
Engine: L98 350
I've got it back they didn't keep it as tight as they could. It is so low It can scrap if I take a hard flat turn . Lb9gta was u lucky enough to have someone in the area that has oval pipe or did you have to order it
Old May 22, 2014 | 11:35 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
I ordered it from Boyce industries.
Then I got a buddy to weld it up for me.
Search my name in the exhaust forum for my pics
Old May 23, 2014 | 08:07 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
I have 2210's with 3" duals and I do not scrape. I'm lowered also. Mine ends jus before the rear end though.
Old May 23, 2014 | 08:38 AM
Car: 88 Iroc Z
Engine: L98 350
I like the way ur exhaust is ran. That's the way I wanted to run it and the exhaust shop missed up. Hopefully the next shop will do better. Did u run oval in that section?
Attached Thumbnails help!!!in exhaust shop 2210 can i fit dual 3" to third member?-wp_20140522_14_11_19_pro.jpg   help!!!in exhaust shop 2210 can i fit dual 3" to third member?-wp_20140522_14_11_24_pro.jpg   help!!!in exhaust shop 2210 can i fit dual 3" to third member?-wp_20140522_14_12_16_pro.jpg
Old May 23, 2014 | 09:26 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
They butchered that.
Old May 24, 2014 | 10:23 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
If you're talking about my exhaust, I modified the trans crossmember.
Plus the 3" oval pipe is 3/4" shorter than a round 3" pipe.
Old May 29, 2014 | 09:59 PM
ziggy89's Avatar
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
just got my heddman s tensions ill be able to tuck it up close but im not sure it will be enough. may just have to order the 2.5 vesions. its a tight fit with an aftermarket cross member
Old May 30, 2014 | 09:38 AM
Car: 88 Iroc Z
Engine: L98 350
These are the pictures of my exhaust redone 3" to 4"Y with a dump vavle and better clearance than the last time ill post clearance pics in a lit bit
Attached Thumbnails help!!!in exhaust shop 2210 can i fit dual 3" to third member?-wp_20140529_18_36_54_pro.jpg   help!!!in exhaust shop 2210 can i fit dual 3" to third member?-wp_20140529_18_37_15_pro.jpg   help!!!in exhaust shop 2210 can i fit dual 3" to third member?-wp_20140529_18_38_00_pro.jpg
Old May 30, 2014 | 01:54 PM
PAFORM350's Avatar
Car: 1992 Formula 350
Engine: 5.7 L98
Night and day
Old Jun 9, 2014 | 01:02 PM
Car: 88 Iroc Z
Engine: L98 350
Here's a few clearance pics to get an idea still don't like speed bumps and parking lots with a step transition but seems like its going to be okay on 98%+ of public roads
Attached Thumbnails help!!!in exhaust shop 2210 can i fit dual 3" to third member?-wp_20140529_18_38_59_pro.jpg   help!!!in exhaust shop 2210 can i fit dual 3" to third member?-wp_20140529_18_39_29_pro.jpg   help!!!in exhaust shop 2210 can i fit dual 3" to third member?-wp_20140529_18_40_13_pro.jpg
Old Jun 9, 2014 | 01:07 PM
Car: 88 Iroc Z
Engine: L98 350
The last pic I think the guy got a lit excessive on the bend but not to bad. If I ever redo it ill send this section of exhaust in and get it redone in oval
Attached Thumbnails help!!!in exhaust shop 2210 can i fit dual 3" to third member?-wp_20140529_18_41_15_pro.jpg   help!!!in exhaust shop 2210 can i fit dual 3" to third member?-wp_20140529_18_44_48_pro.jpg
Old Jun 9, 2014 | 01:16 PM
Ghettobird52's Avatar
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
Looks 1000X better than previous setup, i like it!!!! Except that last pic showing how much he had to hammer it in/bend it to fit, ouch.
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
Street Lethal
Apr 30, 2019 12:14 PM
PestilenceIV
Aug 20, 2015 02:33 AM
