Trans crossmember to ground clearance
Old May 16, 2014 | 06:51 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
On a typical thirdgen, what is the measurement from the transmission crossmember to the ground?
I need to fit my 3" down pipe under the trans crossmember. I don't think I can go over it.
-- Joe
Old May 19, 2014 | 08:30 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: Trans crossmember to ground clearance
Factory assembly line height at the frame rail overlap alignment holes is 13.22" (if basic math doesn't fail me... 336mm). The x-member is further back and roughly 1" further from the ground. Assuming datum line refers to assembled ride height, of course...hth
Attached Thumbnails Trans crossmember to ground clearance-2014-05-19-19.54.04.jpg
Old May 19, 2014 | 08:44 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Hrmm. Interesting. That would leave me to believe I've got plenty of room to run the pipe under the crossmember.
Thanks!
-- Joe
Old May 20, 2014 | 07:03 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
-- Joe
I have true dual 2.5" pipes running under my cross member (and I also have a TH350 trans) The picture should give you a decent idea of how much room you have.
*EDIT* I just realized my car is on ramps in that picture, my bad. Either way, the pipes run flush with the bottom of my deep oil pan (as you can see in the pic). I'd imagine there's plenty of room for the single 3" that you're talking about.
Old May 20, 2014 | 07:12 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Yeah that looks pretty good. It appears I was worried for nothing. I guess I'll finish up the exhaust tonight.
I'll probably go to twin 2.5" pipes when I switch to twin turbo's next year. Right now I have a single T76 turbo with 3" downpipe.
-- Joe
Old May 22, 2014 | 10:32 PM
chevyredneck8's Avatar
Car: 88 Iroc Z
Engine: L98 350
Transmission: 700 R4
Here is a few pics of 3" under the transmission cross member ran yesterday. I've drove 15 miles and almost scrapped through it. Its going to another exhaust shop tomorrow I'm going to to go around the hang down spot on the cross member. Mine are sphoon crossmember but hopefully this gives you and ideal. I'll update what this shop manages to do
Attached Thumbnails Trans crossmember to ground clearance-wp_20140522_14_12_16_pro.jpg   Trans crossmember to ground clearance-wp_20140522_14_11_19_pro.jpg   Trans crossmember to ground clearance-wp_20140522_14_11_24_pro.jpg
Old May 23, 2014 | 04:50 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Looks like that spohn crossmember hangs down way lower than OEM huh?
I stopped here. Gonna finish it this weekend and see where we are at. Might oval the tube under the crossmember.
-- Joe
Attached Thumbnails Trans crossmember to ground clearance-img_20140511_201304.jpg   Trans crossmember to ground clearance-img_20140511_201316.jpg   Trans crossmember to ground clearance-img_20140511_202319.jpg
Old May 23, 2014 | 08:30 AM
Car: 88 Iroc Z
Engine: L98 350
Updated pics with clearance pics coming
Attached Thumbnails Trans crossmember to ground clearance-wp_20140529_18_37_15_pro.jpg   Trans crossmember to ground clearance-wp_20140529_18_38_00_pro.jpg   Trans crossmember to ground clearance-wp_20140529_18_38_59_pro.jpg
Old May 24, 2014 | 10:36 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
So I cut up the crossmember, and welded some 1/4" channel stock to it. I tucked the pipe as close up as I could.
Seems to have about 6+ inches of ground clearance.
-- Joe
Attached Thumbnails Trans crossmember to ground clearance-exh1.jpg   Trans crossmember to ground clearance-exh2.jpg
Old Jun 9, 2014 | 01:39 PM
Car: 88 Iroc Z
Engine: L98 350
More clearance measurements
Attached Thumbnails Trans crossmember to ground clearance-wp_20140529_18_39_29_pro.jpg   Trans crossmember to ground clearance-wp_20140529_18_40_13_pro.jpg   Trans crossmember to ground clearance-wp_20140529_18_41_15_pro.jpg
Old Jun 9, 2014 | 01:48 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Is that a pit? I haven't seen a pit in a garage in years!
-- Joe
Old Jun 9, 2014 | 02:25 PM
Car: 88 Iroc Z
Engine: L98 350
Yes sir I love the pit especially for engines that pull through the hood its easy to have someone up top and below. Its about impossible to build a new one with all the regulations involved with them now
eightsixseven
Dec 16, 2024 01:50 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Thomas
Exterior Parts for Sale
21
Oct 7, 2015 05:33 PM
Thomas
Oct 3, 2015 05:34 PM
Elliswon
Aug 10, 2015 12:33 PM
