Old Aug 8, 2014 | 04:24 PM
$A_Money$'s Avatar
Car: 1991 camaro
Engine: 305 tbi
Transmission: auto
Anyone runnin exhaust out in front of the rear tires? Is there enough room to run true duals down eachside of the car?
Old Aug 8, 2014 | 05:00 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: ??
I believe there was a thread by someone who did that. Somehow cut into the rocker panel so the exhaust exit was through the panel not under the car. Can remember exactly how it was done but looked cool.
Old Aug 8, 2014 | 05:56 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Re: ??
Not the one I was thinking of but similar idea.
https://www.thirdgen.org/forums/exha...ide-pipes.html
Old Aug 9, 2014 | 03:54 PM
$A_Money$'s Avatar
Car: 1991 camaro
Engine: 305 tbi
Transmission: auto
Re: ??
I didn't know if anyone had done it or not an made it look decent I was thinkin of doin it myself to do true duals an run em out in front of the rear tires I just didn't kno if anyone had pics or thoughts
Old Aug 10, 2014 | 01:56 PM
twowwwerf's Avatar
Re: ??
I would love to see some pictures of a well executed system! If you decide to do it, post it up!
Old Aug 11, 2014 | 06:56 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Re: ??
I have true duals that dump just before the rear axle. If that gives you any kind of idea of what it would look like/require.
Old Aug 11, 2014 | 06:57 AM
Car: 1983 Z28
Re: ??
I have 2.5" pipes and about 4-5" of ground clearance. (with a 28" rear tire)
Old Aug 25, 2014 | 02:48 PM
$A_Money$'s Avatar
Car: 1991 camaro
Engine: 305 tbi
Transmission: auto
Re: ??
I finally did mine its 2.5 inch pipe from the manifolds back into flowmaster original 40s
Old Aug 25, 2014 | 02:50 PM
Car: 1983 Z28
Re: ??
Cool. glad you got it going.
Old Aug 25, 2014 | 05:28 PM
$A_Money$'s Avatar
Car: 1991 camaro
Engine: 305 tbi
Transmission: auto
Re: ??
yea me too its a lil lower than I wanted but that's fine I guess haha
Old Aug 25, 2014 | 07:04 PM
dixie wrecked's Avatar
Car: 91 ws6
Engine: Carb'd 334 stroker
For more clearance, ya can always do side pipes. I'm running true duals, side pipes that lead to stacks, only clearance issue is the collector. I just welded em too low so they bottom out from time to time, but that's it.
Using shorties, I just welded on bent pipe to exit to the side just in front of doors, then ran pipe straight back to behind the doors, 90° turn upwards and bolted the stacks to the side of the car
Old Aug 26, 2014 | 02:50 PM
$A_Money$'s Avatar
Car: 1991 camaro
Engine: 305 tbi
Transmission: auto
Re: ??
the only place im rubbin is right behind the rear driver side tire bcz of where I welded it kinda hangin low also if I want to ill cut it an re weld it kinda up tighter but right now im good with it
