sub frame connectors
Old Aug 15, 2014 | 08:56 PM
fireball318's Avatar
Car: 92 Z-28
Engine: 5.7
Transmission: 700 r4
Axle/Gears: ?
Just bought a 91 Camaro, it has sub frame connectors installed on it. Car has 88,000 miles on all original except for connectors and strait pipe exhaust. I would prefer to have car all original, but now that it is not what have you guys done with your exhaust with connectors installed because it looks like there is no clearance for pipe in stock location, as far as under passenger side floor board? Thanks for any help. Side not I have bought walker intermediate pipe, muffler, and tail pipes just wondering why they make all the connections the same size. Meaning I thought they would all slip together then weld or clamp.
Old Aug 16, 2014 | 01:25 AM
NowhereFast's Avatar
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
Re: sub frame connectors
My SFCs are UMI, so they might be different, but you can see it's run in the stock location.
Old Aug 16, 2014 | 01:56 PM
akanitro's Avatar
Car: 1989 GTA, 2004 Z06, 2008 Expedition
Engine: L98, LS3, 5.4L
Transmission: 700R4, MN6, Auto
Axle/Gears: 3.23, 3.42, ?
Just a note from experience: The UMI bars are great but if you use SLP headers and Y-pipe, the small bracket that welds from the passenger side bar to the inner frame rail will not clear. Stock exhaust still gives you plenty of clearance due to a smaller diameter Y-Pipe.
Old Aug 16, 2014 | 03:01 PM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
I have a 91 Formula, Spohn outer SFC's, Alston inner SFC's, Hooker 2055's (jet hot) and 3" Magnaflow cat, Flowmaster cat back, 1 in 1 out, 30 series, all in the stock locations...
Rafael
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
91 SrS
Oct 7, 2015 04:32 PM
meeklay812
Oct 1, 2015 03:46 PM
RS Reaper
Sep 27, 2015 07:04 PM
