Original Tail pipes question
Car: 85-6 TA 85 IROC 82-86 MSE 83 Pace
Engine: Slow ones
Transmission: Noisy ones
Axle/Gears: Weak ones
I want to put Original tail pipes back on my car but like everything else i cannot find them.
which one of these would be the closest to the original set?
http://shop.advanceautoparts.com/web...hedFrom=header
http://www.ebay.com/itm/Walker-43988...4c50a1&vxp=mtr
Also if anyone knows a better set or were to get reproductions at please post were.
Re: Original Tail pipes question
walker and dynomax are the same comany (dynomax is walker's performance line), so they're likely _exactly_ the same unless they're different diameters.
Those appear to be shaped correctly but the originals did not have the ribbed style crush bends (although I've had walker/dynomax show them one way in the pics and them come the other, so that doesn't help you much).
A good exhaust shop with a tubing bender should be able to reproduce the factory ones close to exactly, just make what you see in those pics with regular tubing bender crush bends...
Well, actually you need to cut off the tips of the slash cuts flat also... hopefully you know what I'm talking about- I just did a google search and couldn't find a pic...
Transmission: 5-Speed Manual
Here's An Old Post It Might Help,The Dynomax Tail Pipes Are Not Ribbed.
https://www.thirdgen.org/forums/hist...1-exhaust.html
