Transmission: 5-Speed Manual
Car: 1988 SC Convertible
Engine: 5.0
Re: Exhaust
Can anyone who has the OEM exhaust on thier camaro tell me the diameter of the tail pipes or have a photo of the factory exhaust?
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
Re: Exhaust
Why not hang a Flowmaster, Magnaflo, or other brand in there? Walker is not the only one. The tips can be cut to match an original set-up at the shop that installs them. I think the cat back tubes are 2" or 2.5".
Engine: 5.0
Re: Exhaust
I looked at Walker exhaust and found a cat back system that looked OEM except the tail pipes had a outer diameter of 2" and the pipes had ribbed bends. During my search, I noticed the DynoMax cat back system part #17493, which is made by Walker exhaust and It looks OEM.
Engine: 5.0
Re: Exhaust
Thank you gt4373 for your help!! If you get a moment check out the DynoMax cat back system I referenced above. It's close in appearance to your stock exhaust. Let me know what you think. The DynoMax system is 2.5" as well..
david068513
Sep 18, 2015 10:36 AM
