Catalytic Converter
Car: Transam, 85
Engine: 305 HO, 4bbl Carb, G Engine
Transmission: 5 Speed
Catalytic Converter
What kind of gasket/spacer goes between converter flange and the exhaust pipe flange. If there is none, wouldn't it leak exhaust.
Car: '85 Trans Am
Engine: 305 LG4 4BBL
Re: Catalytic Converter
I'm sorry man I really don't know hopefully someone will chime in.
I'm thinking the same as you...no gasket=exhaust leak
Car: camaro
Engine: 3.1
Transmission: auto
im no expert. however when I took my old cat off there was nothing there. when I put my new one on I didn't use anything. just tightened everything down real well and there is no leak. turned the car on and ran my hand over both ends while a buddy reved the engine.
maybe some one more knowledgeable can chime in.
Car: 1990 Trans Am
Axle/Gears: Stock
They didn't get any gaskets from the factory.
Sounds dumb, but that's the way it is.
As the headers and heads were new, there wasn't any deformation to produce a leak and I'm surprised that my two Birds have never had an issue with leaks at the headers in all those years.
Car: 1988 Camaro
IIRC...If the ends are flat/flush the it needs a gasket. If the mounting plate is offset with alittle pipe nub sticking out past the flange, then it's a ball and socket design and no gasket is needed
Gasket needed on this one http://www.hawksthirdgenparts.com/83...ainless-steel/
No gasket needed on this one http://www.hawksthirdgenparts.com/82...ainless-steel/
Car: Transam, 85
Knight Rider,
Per your photo, I have the flash one.
Can I buy the gasket at Autozone, Advance, Napa, Pep Boys, & what would be the part #, ..................or is this some sort of paste type.
Transmission: 5-Speed Manual
Thirdgen89GTA
Nov 26, 2015 11:04 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
