3 1/2in cat-back
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
3 1/2in cat-back
How much HP do you think I can gain with a 3 1/2in cat-back? Look at my sig!
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: 3 1/2in cat-back
10-15 whp my guess. Try disconnecting current catback at the y to see if it helps.
Car: 89 Iroc-z
Transmission: TH400
You are makin great numbers for that setup. It def should pick up if muffler flow doesnt restrict it. I have seen 7-15 whp gains with cutouts on similar power setups, bypassing the 3" catbacks
This is about the only thing thats left for me to do to create more power out of this combo. The rest of it is getting the power to the ground and my driving. It should be able to run in the mid 11's@120+mph as it stands.
Car: 89 Iroc-z
Transmission: TH400
Yup my 383 made 392 whp heat soaked on last pull. Ran 119 mph that night in ok air conditions at 3450 lbs
Car: 91 Z28
Engine: 6.0L LQ9
Axle/Gears: Dana 44 3.92
you're not losing anything with a hooker max flow muffler, it flows as much as the 3" pipe. the 3" might be the only thing holding you back, other than the cats.
Well since I'm in Cali I need the cats. Beside I don't like the raw exhaust smell. It stays on your clothes. 3 1/2 I think is the way to go
Car: 91 Z28
Engine: 6.0L LQ9
