thermostatic air cleaner?
Old Jan 19, 2015 | 04:28 PM
kanaka4rmcali's Avatar
Car: 1990 Camaro RS
Engine: L03 305 TBI
Car wouldn't pass smog after my mechanic installed my hooker header 2055s. So the smog technician said I need a thermostatic air cleaner, any ideas on where I can buy one?
And isn't it false advertisement because on jeggs it says that the headers are 50state smog legal?
Old Jan 19, 2015 | 04:44 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
Re: thermostatic air cleaner?
It's your factory air cleaner. They want to see that pre heater hose going from the exhaust manifold to the air cleaner. I had to buy an adapter to the headers so mine would pass.
Old Jan 19, 2015 | 06:57 PM
Car: 1990 Camaro RS
Engine: L03 305 TBI
Where did u get the adapter from?
Old Jan 19, 2015 | 07:18 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Summit racing. It's called a heat stove. Jegs may have it. The one I bought is not a two piece but a single piece that is just clamped onto the header so it can later be removed. I just checked the site and it says Edelbrock is discontinuing. I'll post a pic of the part if my ipad lets me. Maybe a shop can make one out of some stainless exhaust pipe or cut one off a wrecking yard exhaust manifold from another third gen or other car that will fit the hose.
Old Jan 22, 2015 | 06:24 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
If your headers are non coated, just take it to a competent exhaust shop, show them the above picture, explain that you need a heat tube and they can fab you up something. I added it to my old G20 by sectioning part of a short section of pipe and spot welding it over one of the header tubes. The revised heat source actually warmed up more quickly than the stock manifold/heatshield setup.
Bubbajones_ya
Jul 6, 2024 08:32 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
edoff13
Sep 11, 2015 03:55 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
