421 stroker Header advice
Old Feb 14, 2015 | 08:29 AM
IROCZ1989's Avatar
Car: 1989 IrocZ
Engine: 421 Dart Stroker
Transmission: 4L60E Cahall Performance Built
Axle/Gears: Midwest Chassis Fab 9/ 3.55 gears
My 421 is just about done. Right now I have the hawks 1 3/4 long tubes with 2 1/2 collector. Im thinking the collector is about 1/2 to small. Been reading alot into primary size and it seems the 1 3/4 inch should be fine considering my rpm redline is in the lower 6000s. They do offer the same header with a 3 inch collector. Hp should be around 600 crank. Nitrous is an option. Thanks
Old Feb 14, 2015 | 12:09 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
Re: 421 stroker Header advice
hooker makes them with 3" outlets you shouldn't have 2 1/2 on those 1 3/4 that's gonna be the choke point on your exhaust
Old Feb 14, 2015 | 02:15 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
You need 3".
Could sell urs and buy new set. Or cut collectors off and weld new ones on that have 3".
Old Feb 15, 2015 | 12:54 PM
Ingram78's Avatar
Car: 1985 firebird
Engine: 360"sbc NA pump gas
Transmission: Th350 manual valve body
Axle/Gears: Moser 12 bolt 4.11:1
Have doug's long tube 1.75" and 3" collectors ceramic coated on mine. From jegs I believe
Old Feb 19, 2015 | 01:33 PM
IROCZ1989's Avatar
Car: 1989 IrocZ
Dougs make them for our years?
Old Feb 19, 2015 | 01:52 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Yes they do
Old Feb 20, 2015 | 03:19 PM
RWB____s's Avatar
Car: Z/28
Engine: 355
Transmission: Turbo 400
my guess would be that 1-3/4 primary tubes will be to small for that size engine to start with. If or when you add nitrous, it will get much worse. try a stepped header 1-7/8-2.0 primary with at least a 3" collector. Oh bring lots of $$ for headers if you decide to change up in size.
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
Jlanz55
Sep 6, 2015 07:28 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
IROCZ1989
Sep 4, 2015 11:54 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
