o2 sensor placement with headers
Old Apr 29, 2015 | 11:53 PM
drathaar907's Avatar
Car: 1985 WS6 Lear-Siegler Leather Black
Ordering headers soon for my son's 85' TPI 305. Question? How/where do you hook up the O2 sensor? I see it is bolted into stock manifold. Is there a a threaded port/hole in the headers when they come? Planning on removing EGR and delete it as well as smog tubes/pump.
Old May 3, 2015 | 11:23 PM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
Re: o2 sensor placement with headers
You'll probably have to weld on an o2 bung. It's best to mock up your exhaust then decide where you can best locate the sensor where it's not in the way of anything else. Which is probably why you'd be hard pressed to find headers with a bung in place already...that and some guys are running carbs that don't require o2. Best place to put it is on/near the collector where the 4 tubes come together. Keep in mind that you'll probably have to run a heated/powered o2 sensor once you go to headers.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
Ironhead38
Sep 7, 2015 02:26 PM
Eric-86sc
Sep 7, 2015 02:10 PM
willyjoejr
Sep 3, 2015 09:26 AM
