Hawks headers and 4L60E
Old May 21, 2015 | 10:17 AM
gamewiz83's Avatar
Hey guys,
I'm doing an LS1 swap with the auto tranny into my 92 Z28. Any one who has done this swap please chime in if you know the answer to this.
I'm looking to get the 1 3/4 headers with the 3in collectors. I need to know if there is enough clearance between the headers and the tranny pan if I was looking to do a Y pipe that wrapped around it? I was told on a T56 it's not a problem because the pan is much narrower but the auto is a different story.
I'm looking to avoid running the exhaust under because of ground clearance.
Car will also run cats if that helps because I have to pass emissions.
Any help is appreciated especially if you have this exact same configuration. Anyone with pictures please post them.
Old May 21, 2015 | 05:40 PM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
Re: Hawks headers and 4L60E
I have hawks 1 3/4 headers with 3in collectors. I have some pretty good pics showing the headers before and after the y-pipe was hooked up to give you a good idea of how they will sit in relation to the transmission and frame. I used 3 bolt flanges on mine, the passenger side was too close to the frame so I put a slight bend in it. The pipe is reduced to 2.5in. right after the header, you could fit 3in without much issue. I have 3.5in mufflex system after the Y pipe.
Attached Thumbnails Hawks headers and 4L60E-headers1.jpg   Hawks headers and 4L60E-headers4.jpg   Hawks headers and 4L60E-headers5.jpg   Hawks headers and 4L60E-headers7.jpg   Hawks headers and 4L60E-exhaust1.jpg
Old May 21, 2015 | 06:42 PM
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Axle/Gears: MW 3.42 12 Bolt
Nice job, jbenge.
Like you said, the problem is the pass side.
I made the trans cross-member attach side-to-side to free up room and even slightly scalloped the frame rail to keep it up tight and have room. I had to section the pipe, too (but the alignment shop crunched the pipe anyway ). In the thumbnail, black is where I sectioned, red where I scalloped, and green where I x-member attached.
I guess I should get around to POR-15 this weekend.
Old May 21, 2015 | 09:17 PM
gamewiz83's Avatar
Thanks to both of you for the quick replies as well as the detailed pictures. I feel much better now that I can see whats been done to accomodate the tight fit.
Cheers!
Fronzizzle
Feb 9, 2017 09:31 AM
Chad Speier
Sep 24, 2015 12:32 PM
Night rider327
Sep 16, 2015 02:20 AM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
