header with ground clearance
Old Sep 14, 2015 | 11:11 PM
83RDRACR's Avatar
Hey guys, I am building a track day/ road race car and am looking for a long tube header that won't hang down past the factory front sub frame that runs along side the transmission. Engine is 383 stroker that dyno'd at 455hp so could use a 1 3/4 primary. Most that I have looked at seem to hang below the frame rails by an inch or so. I have moved the frame rails outward and fabbed a double hunp crossmember so there is room to run the exhaust along side the trans.
Any suggestions would be appreciated.
Old Sep 15, 2015 | 08:18 PM
formula350sd's Avatar
Car: 89 Formula
Engine: 383 vortec tpi
Transmission: t56 woot
Re: header with ground clearance
Tightest long tube I've seen are the Hawks.
I've had them and super comps the hawks fit and install much easier
Old Sep 16, 2015 | 01:42 PM
83RDRACR's Avatar
The Hawk headers, are those the ones made by stainless works?
Old Oct 19, 2015 | 01:25 PM
Jackrabbit501's Avatar
Car: 1986 Camaro
Engine: 355 tpi
These are my dougs d3321 headers. I had the hedman longtubes in there before, but these ones seem to fit better but they do hang just a little lower than the hedmans. Those are the only 2 i have messed with
Old Oct 24, 2015 | 12:40 PM
83RDRACR's Avatar
jackrabbit, thanks for the info and pics. The dougs look like they hang down below the factory frame rails quite a bit. i only have about 5" of clearance ther. Was hoping to get something that tucks up a little closer.
Dave
Old Mar 26, 2016 | 08:13 PM
Car: 89 Formula
This is months late but yes.
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
billybob6110
Sep 23, 2015 01:30 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
