How big does the cat back need to be
Old Dec 21, 2001 | 08:18 PM
david auster's Avatar
Car: 1992 Camaro
Engine: 350 miniram
I have a catback with a 2.75" I pipe and I was wondering how much power you can put through it before it becomes a restriction.
I have no idea how much power this combo will make but I am wondering if I would benefit any by going to a 3in catback. The motor is a 305 TPI, (TPIS base, SLP runners, LPE plenum, BBK 52mm TB) It has the ZZ4 aluminum heads and the ZZ4 camshaft. I am using heddman 1 5/8" headers and the heddman y-pipe, stock cat and stock I pipe to a flowmaster. So would it make any difference to switch over? If a 2.75" pipe can flow enough I would prefer not to spend anymore money and just use what I got. by the way I am also running a 5 speed if that matters. Anyway let me know what you think.
Old Dec 21, 2001 | 08:30 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I don't remember the numbers exactly, but it was posted a while back. I believe you want to get 3" pipe when you're in the 275hp-300hp range.
Old Dec 22, 2001 | 09:16 AM
Car: 1992 Camaro
Engine: 350 miniram
Are those flywheel #'s your talking about or at the rear wheels?
Like I said, I have no idea what kind of #'s my combo will put down so does anybody think that the 2.75" will be restricting power and if I went up to a 3" pipe how much extra power could I get?
Old Dec 22, 2001 | 10:07 AM
Car: 99 Formula
Axle/Gears: 342
Yes, those are flywheel #s. With your setup with the heads and cam, I would definately get the 3".
Vintageracer
Jan 10, 2020 05:33 PM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
drathaar907
Aug 6, 2015 04:20 PM
