Headers increase head exhaust cc?
Old Jan 19, 2016 | 01:17 AM
87hellbird's Avatar
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
So I am trying to keep my engine all tuned to the correct intake to exhaust cfm on heads and I am trying to figure out if compared to the stock manifolds and stock exhaust, if headers and a tuned length exhaust increases the cfm on the exhaust side of the heads. Its a hotter cam 305 and have the intake fully ported and a bunch of other aftermarket things. But before grinding on exhaust ports I wanna keep the intake to exhaust under 70%
Old Jan 19, 2016 | 06:59 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Headers increase head exhaust cc?
If the header is built to the motors requirements for exhaust size then it will have an increased effect on extracting flow from the cylinder during blowdown. It will scavenge more, pulling on the charge which helps draw new intake air in.
Head port isnt changing in physical form. You are just getting more out of it by exhaust tuning
Now on a flow bench, perhaps pipe size and shape may show different flow numbers for the port, just like on the intake port size, different radius bell mouths vs clay inlets etc all have effects on the cfm you measure.
87hellbird
Jan 18, 2016 07:14 PM
WASyL
Jan 17, 2016 02:36 PM
FinnZ28
Dec 27, 2015 11:02 AM
eduardosac
Dec 27, 2015 12:24 AM
FinnZ28
Dec 24, 2015 04:31 PM
