converting from dual cat to single with a Magnaflow ypipe
Old Jan 29, 2016 | 03:04 PM
BOTTLEDZ28's Avatar
Transmission: A4
Have any of you OEM dual cat guys replaced the factory ypipe for a single cat Magnaflow setup? Was it a direct bolt in when going with a Magnaflow catback setup as well?
Old Jan 30, 2016 | 01:52 PM
thtanner's Avatar
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
Re: converting from dual cat to single with a Magnaflow ypipe
I replaced my stock cats with Magnaflow High-Flow cats, kept the factory Y pipe and just had my muffler guy cut out the old ones and weld em in.
If you are lucky enough to have the dual cat option, I'd keep it. Less restrictions the better!
Old Jan 30, 2016 | 03:20 PM
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
If you do replace the dual cats, I'll buy your old ones!
Old Jan 30, 2016 | 05:13 PM
BOTTLEDZ28's Avatar
Transmission: A4
Well the car has 50K miles on it. Im sure the cats are fine but if I replace the system it will only be for a stainless setup and a slightly better sound. The OEM exhaust on the car shows no signs of any rust at all.
Old Jan 31, 2016 | 07:42 AM
PurelyPMD's Avatar
Engine: LB9
Cool, let me know - I'd come up & pick it up.....I'll bring cash with me too.
HP52TA
Oct 26, 2020 09:12 PM
dpmalibu
Exterior Parts for Sale
Feb 7, 2016 07:53 AM
AmpleUnicorn88
Feb 2, 2016 02:24 PM
bryan623
Jan 30, 2016 10:37 AM
tcrisp
Jan 25, 2016 07:15 AM
