Long tube header install on thirdgen
Old Mar 12, 2016 | 03:53 PM
CRAZYCHUCK13's Avatar
Car: 91 Z28
Engine: 383-Carb
Transmission: TH400/3500 Stall
I'm trying to install long tube headers on my 91 Z28. Passenger side is installed. Having trouble with drivers side. I pulled all spark plugs & oil pressure sending unit.I have pulled drivers side motor mount bolt n raised eng.but I haven't removed oil filter. Anyone have suggestions to install through to or bottom?
Old Mar 12, 2016 | 08:30 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Re: Long tube header install on thirdgen
There are several threads that go through whats needed, but whats needed also depends on what headers you have.
Traxion's Hooker 2210 Long Tube install thread is probably the best documented install I know of. its a sticky at the top of this forum.
But there isnt' much to installing them. Keep trying, see what they hit, then find ways around it.
My 2210's took probably 4 hours to install. However, thats because I kept having to change things like brake line routing, knock sensor location....etc.
Now that everything is clearance it takes about an hour to pull them out of the car, or put them in. Thats accounting for Y-pipe, spark plugs..etc.
Old Mar 13, 2016 | 01:42 AM
357's Avatar
357
Car: 87 TransAm T-Top
Engine: 360 SBC,AFR195,Full Roller 600 lift
Transmission: 350TH
Axle/Gears: 12bolt 4:56
I would remove the oil filter.
Old Mar 13, 2016 | 04:16 PM
Car: 91 Z28
Engine: 383-Carb
Thanks guys.
I
Yes I was planning on removing oil filter. Think I might have to raise up front end some more.got car on 4 jack stands about a foot or so off ground. Headers ar made by Stainless Works out of Ohio. Any additional information would be greatly appreciated, thanks again for all your help.
Old Apr 14, 2016 | 03:51 PM
hotrodaj's Avatar
Engine: 406 SBC
Transmission: 700R
Axle/Gears: Std 10 Bolt 3.73
Hey Crazychuck13 HOw did the install turn out? I just bought SW from hawk's and will be doing the install in the next few weeks. Any tips would be awesome!!!
Old Apr 15, 2016 | 04:30 AM
Car: 91 Z28
Engine: 383-Carb
Very tight fit.starter has to be removed. You will need the smaller mini starter you can find (I got mine from jegs).drivers side , you will have to remove motor mount bolt raise eng, remove oil filter n oil sending unit.lower eng the bolt up header.dipstick will also have to be removed .I your using the nice BMR torque arm and trans mount, forget about that mount. Will not clear exhaust. I had to use my stock trans crossmember weld in a piece of 1/4"×3"×8" flat stock for torque arm mount (for BMR torque arm).found mouth bracket at jegs (hooker headers makes a bolt on bracket that works).if using stock torque arm that mounts to trans, you should be ok! Good luck! Any questions feel free to hit me back!
Old Apr 15, 2016 | 01:41 PM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
my Hedmans slide right in, but i did have to take the starter out to do it and had to do some "massaging" of a couple of tubes on each side when i first put them in 4 years ago..
now that i've swapped in a 5 speed, i needed to dent the collector on the driver's side, but i think i'm going to redo it with a set of homemade merge collectors instead because at leas that looks like something you'd see on a race car...
Old Apr 15, 2016 | 06:12 PM
UltRoadWarrior9's Avatar
Car: 1986 IROC Z-28
Engine: 383 Gen I SBC 11:1
Transmission: Rebuilt TH700R4 for 500+HP
Axle/Gears: 4th Gen 10 bolt Eaton Truetrac 3.23
I've just received some OBX Racers longtube headers I purchased a few days ago from Ebay. I won't mention the price as it may make some people sick to their stomach. They are pretty much identical to Stainless Works. Bolts or studs for these types of headers? Studs would be nice since you could put the gaskets in place then slide the headers on. But is there enough room? The OBX kit comes with individual exhaust gaskets for each exhaust port, not sure about the SW kit...
Old Apr 15, 2016 | 07:29 PM
Car: 1986 IROC Z-28
A useful link:https://www.thirdgen.org/forums/afte...longtubes.html
Old Apr 19, 2016 | 12:27 AM
badgta's Avatar
Car: 1991 FORMULA
Engine: ZZ4 + LT4 HT CAM 430HP
Transmission: 700-R4 COMING T56
Axle/Gears: 9" 4.56's (COMING)
Hedman 68460's will drop in with some light work. Mine did anyway way back when.
Old Apr 19, 2016 | 02:13 AM
novaderrik's Avatar
Car: 86 Camaro
bolts... throw the gaskets that came with the headers away and get some copper gaskets. loosely hang the headers in place with the end bolts, then drop the gasket in with the raised ring toward the head, then put the rest of the bolts in and tighten it down.
Old Apr 19, 2016 | 05:37 PM
Car: 1986 IROC Z-28
Roger that. Thanks alot!
Old Apr 19, 2016 | 08:53 PM
no new tires's Avatar
Car: 88 IROC-Z
Engine: GEN 4 LY6 (going forged 408)
Transmission: 60E (going RPM LEVEL 6 4L80E)
Axle/Gears: 7.5" 3.42 (staying...)
I dont know why guys are having to jack the motor up. crazy- I didn't have to do that.
Old Apr 19, 2016 | 08:59 PM
It depends on what headers you have. For my 2210LT's I don't have to jack the engine up. But I do have to remove/install the starter at the exact same time as the passenger header. Its just one of those things.
Old Apr 22, 2016 | 07:58 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I went with the OBX 1 3/4" stainless long tubes. No issues at all. Almost fell in.
-- Joe
Old Apr 26, 2016 | 05:59 PM
Car: 1986 IROC Z-28
Sorry to ask a stupid question but what's the pitch and thread of the manifold bolts for the 1986 SBC stock heads? AND are they the same for the AFR heads?
Old Apr 27, 2016 | 09:11 AM
3/8"-16
Yes
Old Apr 27, 2016 | 09:37 AM
Car: 1986 IROC Z-28
Sofa you're a lifesaver. I don't care what anyone else says about you.
I'm about to put a sizeable order into Summit for my 383 engine build and some extraneous stuff for my current car so I can mount this OBX exhaust system. Thx!
Old Apr 27, 2016 | 09:38 AM
You don't even want to hear what THEY say about me.
Old Apr 27, 2016 | 11:08 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
People hardly bring up the pole dancing anymore..
-- Joe
Old Apr 27, 2016 | 06:55 PM
IROCZ1989's Avatar
Car: 1989 IrocZ
Engine: 421 Dart Stroker
Transmission: 4L60E Cahall Performance Built
Axle/Gears: Midwest Chassis Fab 9/ 3.55 gears
-- Joe
These or the ssworks ones fit like a glove on the thirdgens. Nicest set of longtubes I feel for these cars.
dpmalibu
Mar 26, 2016 10:00 PM
dpmalibu
Mar 16, 2016 06:52 PM
Donald Croes
Mar 14, 2016 02:34 PM
b2tw45p
Mar 10, 2016 01:57 PM
armybyrd
Mar 8, 2016 09:18 PM
