Engine swap
Old Apr 18, 2016 | 09:08 AM
MSgt Luttrell's Avatar
Car: 1986 IROC Z28
Engine: Carburated small block 454
Transmission: Level 3 Raptor 700R4 2600 stall
Axle/Gears: Strange S60 3:73 S Trac Posi
Engine swap
Ok guys, I'm getting real close to swapping in a new 383 small block to replace the stock 305. My question is will the after market aluminum heads on the new engine throw the long tube header collectors off enough that they won't bolt to my dual exhaust pipes? I know the new heads are too tall to run the A/C compressor, just not sure about how much they will move the collectors.
Old Apr 18, 2016 | 10:31 AM
Re: Engine swap
Probably not. Most heads, all that stuff is in the same place.
Probably won't alter anything about the AC either.
Knowing what heads it is would make it possible to be sure.
Old Apr 18, 2016 | 11:22 AM
Car: 1986 IROC Z28
Re: Engine swap
The heads are BluePrint H8002K 195cc SB Chevy Head, I spoke with one of my buddies that is a builder and he verified that they will interfere with the A/C compressor, because of the taller valve cover, but said as long as I use the same headers I'm using now, I shouldn't have any issues with the collectors lining up.
Old Apr 18, 2016 | 11:42 AM
Re: Engine swap
Well then, that's not THE HEADS interfering. That's something else.
Use valve covers that fit rather than blaming it on the heads.
Eric-86sc
Apr 17, 2016 07:43 PM
apie2546
Wheels and Tires
Mar 30, 2016 08:12 AM
backtothe80s
Mar 29, 2016 01:02 PM
Rich92 RS
Northern California
Mar 28, 2016 08:24 PM
89 formula TPI
Mar 28, 2016 08:01 AM
