Leaking headers gasket
Old Aug 24, 2016 | 03:54 PM
WASyL's Avatar
Car: 1988 Pontiac Firebird
Engine: 305 LT1 intake&heads
Transmission: TH700r4
Axle/Gears: 3.73 10bolt GM
So i have 305 with LT1 heads. headman headers (dont know exact model) bolted right up but new gasket dont match and leak. Can anyone tell me which gasket to get to fix this problem? Should i use sbc or lt1 ones? Stock type or aftermarket ?
Best regards
Old Aug 24, 2016 | 06:47 PM
russ&dars t/a's Avatar
Car: 92 Firebird Formula
Engine: 5.0 tbi
Transmission: 700r4/shift-kit
Axle/Gears: 4.11/posi
Re: Leaking headers gasket
I think the easy way is to pull the header and take it to match up the gaskets.
Old Aug 25, 2016 | 01:28 AM
WASyL's Avatar
true, but as i'm form Europe only shipping each set of gasket is additional 10 bucks for transport and taxes, due to i try to find if maybe there is aother way to find a solution
best regrads
Old Aug 25, 2016 | 09:55 PM
mikeyt's Avatar
Car: 92 Camaro
Axle/Gears: stock
I'm not sure if Jeg's has an international number, however I've got the Headman hedders and I'm using a 5 layer aluminum gasket that was about $30 US, I can't think of the name, I just got them and the car running. I put about 300 miles on them and no leaks.
Old Sep 2, 2016 | 12:21 AM
a62belair's Avatar
Car: 88 Firebird, 87 Formula
Engine: 2.8, 5.0
Transmission: both 700R4
Axle/Gears: 3.42,3.45
I use red hi-temp silicone on all my header gaskets with good results. Even had bolts back-out without leaking.
Good luck!
budowski
Carburetors
Apr 12, 2016 10:28 AM
IROC AND ROLL
Mar 29, 2016 09:52 AM
89Zleeper
Mar 16, 2016 06:55 PM
Stell1579
Aftermarket Product Review
Dec 31, 2000 10:04 AM
NewYorker
Sep 17, 2000 09:04 PM
