Longtube Headers and Installation - 85 Trans Am
Car: 1987 Trans Am
Looking to go with a set of eBay headers for my current build. I have read thru some of the long eBay header threads on here and would like some more recent info. Most the links are sold out header systems and I was wondering if these are the "same" as the other knock offs:
http://www.ebay.com/itm/332237660452...%3AMEBIDX%3AIT
and what type of crossmember do I need with these from those of you have installed these type of headers
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
Re: Longtube Headers and Installation - 85 Trans Am
i have a set and love them. mine came from the seller "speed daddy". you will need double humped xmem. HAWKS sells one.
I wouldn't put 1.75" primaries on a 305. I wouldn't even put them on a stock 350. You're going to lose too much bottom end torque, and it's going to move your power band up to where it's you're not going to be able to make the most of it (you're probably going to lose power everywhere. Now, if you're going to replace heads and cam, then they may not be as bad.
http://www.superchevy.com/how-to/148...ders-shootout/
http://www.hotrod.com/articles/how-t...-right-header/
Car: 1987 Trans Am
Are you sure about that cam? I'm showing that's a 5.0 ford cam. I hope you mean the XR282HR cam. Just took a look at your build thread. It should be fine for you. Comp cams has a pretty good FREE program on their site that helps with cam selection and tells you what ball park you should see for your power curve for what cams.
Whew, you're car wouldn't have been very fast with a ford cam in it. It's alright, it's your car. Put what you want in it, even if it is a ford cam :-P Those headers should be could with your setup. Are you going to try to do duals, or are you going to do 3" to muffler after the Y?
Car: 1987 Trans Am
I would like to set up the LTs with a y and hook to an older catback 3" I have. Then when I can do more mods I'll install the panhard relocating kit and run dual pipes from the headers back. Between the hedmans and eBay stainless knock offs which typically fit better with stock suspension and 700r4?
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Car: 1991 Firebird Formula
Engine: 5.7L TBI
Engine: 5.7L TBI
Piecing together an engine with go faster parts does not always make your car go faster unless match the parts at least somewhat. There are some people on here with 1 3/4" primaries on a 305 running high 15's in the 1/4 mile, that with the mods they've done should be running be running 14's but they have 1 3/4" longtubes.
For a street engine, where most of your driving is under 3500 rpm, 1.5" shorties are about where you'd want to be at. For a performance 305, stock or L98 with a slightly better than stock cam, 1 5/8" would still leave you with bottom end power, and keep your engine breathing to red line. 1 3/4 you'd breath past red line, but have a loss of low end torque. Sorry if I'm repeating too much. I'm tired and don't feel like rereading all I've typed.
