headers help
Old Aug 9, 2017 | 11:38 AM
harryo's Avatar
Car: 1989 chevy trk4x4,1994Z28
Engine: 307to400 (colector)
headers help
iv got a 1984 camaro that im going to put a 604 crate motor in it has d port heads, with a kick out oil pan, what headers would be my best choice? i would like to use long tubes 1 3/4 max. or 1 5/8 min.my car is not lowered. im going to keep the AC,power steering, alternator. the car is for the street and maybe a couple of times at the drag strip
Old Aug 9, 2017 | 12:05 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: headers help
How much are you wanting to spend? Though I'm not sure if big block headers for a Thirdgen are still available, the port spacing between big blocks and LS is said to be very close. You may look I to the cost of long tube 1.75 LS headers and just have a shop modify them.
Old Aug 9, 2017 | 12:18 PM
harryo's Avatar
Re: headers help
its a small block. i dont want to spend more than 900. i want to go a with a daul exhaust system
Old Aug 9, 2017 | 03:18 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Re: headers help
Wouldn't a 604 be a big block?
Old Aug 9, 2017 | 04:12 PM
harryo's Avatar
Re: headers help
No it's a small block the 604 is the last the numbers is the casting number the 604 is a racing motor
Old Aug 9, 2017 | 04:14 PM
harryo's Avatar
Re: headers help
Some parts from the zz4 will fit the 604
Old Aug 10, 2017 | 06:18 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Re: headers help
Best fitting for small block would be the hooker long tubes. The fit is fantastic but they aren't great for lowered cars
