No applause, Just throw money :)!!!
Old Jan 7, 2002 | 02:13 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Here's a usefull link to a web page that I found tonight.
It has calculators for these following uses. I know we already have some here. Just letting you know what this site has. It does have a few that we don't have.
1. Figuring your HP by using either your 1/4 mile ET, or your Trap Speed.
2. Tire diameter based on the size printed on the sidewall.
3. MPH to RPM in steps of 500 RPM Starting with 1000RPM and going to 7500RPM
4. Rear end Gear Ratio
5. CFM needed for an engine (given for 4 bbl carbs).
6. Compression Ratio!!!!!!!
7. And finally, 1/8 to 1/4 conversion chart.
There's also a tech link that will give you the actual formulas. That way you can wear out a pencil if you wish to.
Plus a few links to well respected manufactures of HI-PO parts, etc.
AJ
http://www.ondoperformance.com/
Old Jan 7, 2002 | 02:40 AM
AJ_92RS's Avatar
TTT......
Sorry....... I forgot to actually put the link here......DUH!!!!!
AJ
Old Jan 7, 2002 | 08:01 PM
breathment's Avatar
hmm. where else have i seen this post??
could it be the
Exhaust,
TPI,
Tech\General Engine,
Transmissions and Drivetrain,
TBI,
Motor Swap,
Aftermarket Product Review,
and V6 boards?
Old Jan 7, 2002 | 09:57 PM
AJ_92RS's Avatar
Thank GØD for Copy and Paste huh?
I'm just trying to help people. That's all.
AJ
Old Jan 8, 2002 | 12:46 AM
dps8315's Avatar
I just want to say in his defense that, being as I'm new, I appreciated AJ's post
I definately clicked on the link and I'm sure I'll learn lots about compression ratios, which is info I was on the lookout for.
James
Old Jan 9, 2002 | 12:11 AM
breathment's Avatar
in every freaking forum???? i don't mind one or two forums, but it was in like 8 different ones all saying the same crap.
and not only that, but what the heck does it have to do with exhaust and aftermarket parts?? post it where its necessary, yes i agree that its a Very helpful site, but plz don't post it everywhere..
Old Jan 9, 2002 | 01:24 PM
AJ_92RS's Avatar
Are you a moderator? NO!!!!!
Do you see any of them complaining? NO!!!!!
Not everyone uses all the forums. There are quite a few that I don't use all that much, if at all.
And let's see; Is a carb an aftermarket product? YES!!!!!
And is the needed CFM part of the exhaust? No, but it is part of the air flow combo, so why not put it there?
And whats wrong with trying to help people, and making sure anyone who might use it will be able to find it?
You got problems if you think it's a sin to help people!!!!!
And if any of the moderators feel that I have done a bad thing, then they may forbid me from coming to this message board ever again!!!!!
I have that much confidence that you're the only b!tcher here about this. Get a life man!!!!!
AJ
Old Jan 9, 2002 | 04:57 PM
breathment's Avatar
hey look.
https://www.thirdgen.org/techbb2/for...?s=&forumid=10
its the carb forum.. did u post there. NO
you come in here with the title "No applause, Just throw money" like ur a hero or something..
and where did i say it was a sin to help people. huh??? i never said that...
NOTHING, just don't post it everywhere, if people are that stupid that they have to look in 8 different forums and see the SAME message and then finally understand to goto the site only after seeing all post, then they should be shot
then those people obviously dont' know\care much about they're cars and that info would be useless to them anyways.
as i said before, its one thing to post in a few different forums. but 8?
Fanatic1074
Oct 3, 2022 05:57 AM
Bohemian
Nov 25, 2015 09:38 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
racereese
Oct 3, 2015 03:46 PM
ndndndnd
Sep 28, 2015 08:00 AM
