What is the tube off the passenger exhaust?
Old Aug 29, 2018 | 06:32 PM
Barnyard's Avatar
Car: 91 Z28
Engine: 5.7
I have been reviewing the forms, service manual and Google but I have not been able to figure out what this part is. I’m assuming it’s part of the EGR system. It is the tube that runs off the top of the passenger side exhaust and back under the intake. Mine is leaking and I need to figure out part numbers or at least descriptions so I can get parts ordered.
91 z28 350
Old Aug 29, 2018 | 07:11 PM
beths91camaro's Avatar
Car: 87 Iroc vert, t-top
Re: What is the tube off the passenger exhaust?
Smog tubes, I believe is what they are called.
Or air pollution pump tube.
Old Aug 29, 2018 | 09:41 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Sounds like someone put in some corvette parts.
google corvette tpi or look up the manual for a tpi corvette.
the vettes thst had aluminum heads had the egr tube come off thr passanger side exhaust manifold and feed into the intake at the back by the distributor.
Old Aug 29, 2018 | 09:43 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Old Aug 29, 2018 | 10:16 PM
Yeah that's not the usual arrangement for our cars. It came on TPI Vettes because their heads were different.
But yes, it is the EGR tube. (or hose, sometimes) Look it up for about a 89 Vette and see what you get.
Old Aug 29, 2018 | 10:18 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
I think he is talking about the A.I.R. tube. Barnyard, if you follow the tube does it go all the way to the catalytic converter? If so, then it is part of the smog system. It pumps air into the cat to help combustion.
Old Aug 29, 2018 | 10:44 PM
Barnyard's Avatar
Car: 91 Z28
Engine: 5.7
Thanks guys, I thought i was going crazy. Here is the picture, but it looks just like tealman92's photo, just not as good as shape. I will check out the vette's
Old Aug 30, 2018 | 12:33 AM
Yup, Tealman is correct. That is an EGR passage.
Old Sep 3, 2018 | 05:33 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
https://www.ebay.com/itm/1988-1991-C...ty!02861!US!-1
Old Sep 3, 2018 | 05:50 PM
That's an AIR part... exactly the same, except different.
ramicio
Aug 9, 2013 05:25 PM
vincode8
Jun 16, 2006 05:53 PM
Iroc n roll
Mar 20, 2002 05:41 PM
