Full duals completed on the "cheap"
Old Sep 6, 2018 | 01:56 PM
WTR388's Avatar
Car: 87 Trans Am
Sorry for the lack of pics, Not easy when you're on your back in the garage!
Completed a full 2.5" with an h-pipe behind my LS1, out the back using the stock over the axle location. A very tight fit but it DOES clear with the stock panhard brace. I have a founders piece being shipped anyways, as it's very close to rubbing. I just wanted the exhaust finished once I realized how tight it was so I gave myself clearance to the heat shields knowing I was going to order the lowering brace.
For mufflers and used Totalflow knockoffs of the super 10s, I was happy with the construction and the coating, no doubts about their quality.
I used 6 of the 180 degree 2.5" mandrel bends from dynomax to section up for my bends, and made my own h-pipe.
It's tucked up nicely, and despite the angle of the picture, it doesn't hang lower than my subframe connectors or the torque arm.
The sound is great. I had the dynomax version of the LM1 previously, and this is a few dB quieter at WOT, but while cruising in town its not as obnoxious (I really didn't mind that part of the LM1) I can sneak up the driveway enough that it doesn't disturb the neighbours.
The reason I replaced the LM1, was due to a horrible resonating/backpressure type of noise at 2500rpm if I was engine braking to slow down. Sounded like trash. This current set up sounds great no matter what!
I have about 350-400 cdn in to this from the manifolds back which is great, because after we pay duties, shipping, taxes and the exchange I'm looking at nearly $1000 to get something pre-made shipped to my door.
*side note: The rear "frame rails" behind the axle are NOT equal distances from the center of the car. I had nearly a 4" difference from one side to the other because I assumed the rails were the same distance from the center, so in order to get the tips centered I had to make a 2" s-bend on each pipe after the muffler to get them equal distances from the center of the car.
Will hopefully get a sound video now that it's legally on the road after almost 3 years!!!
Old Sep 7, 2018 | 01:04 PM
pg29's Avatar
Car: 88 GTA
Re: Full duals completed on the "cheap"
Sweet ride, are you near Toronto, Ontario? If so, we should go for a cruise. I have a 1988 GTA with an LS1 swap as well.
Old Sep 11, 2018 | 08:00 PM
WTR388's Avatar
Car: 87 Trans Am
I was in the Borden area in 2015, I did all the cruise nights in the area, Bradford, the Wednesday night cruise at the big park in Barrie, Wasaga, Markham etc. Great area for a car guy, there is a cruise night every day of the week... I'm now living in New Brunswick, and the car scene is not the same.
Z2887
Apr 12, 2017 05:28 PM
TIMMYS89GTA
Jun 16, 2014 09:47 AM
onebinky
Nov 9, 2003 06:49 PM
Crazy2.8V6Man
Jul 11, 2002 11:33 PM
